1965 4x4 ?
Old Jun 7, 2013 | 10:23 PM
1966Jacked4x4's Avatar
1966Jacked4x4
1965 4x4 ?
The cab looks like a 1964.
1965 ford 4x4 V8 4 speed
Old Jun 7, 2013 | 10:50 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Has the right cab, but the wrong Styleside bed to be a 1965 F100 4WD.
Cab step: 1961/64 F100/1100, 1965 F100/250 4WD, 1965/66 F350/1100, 1966 F250 4WD.
1957/60 Styleside beds installed on the following 1961/66's: 1961/65 F100/250 4WD, 1961/66 F350, 1962/63 F100/250 2WD, 1966 F250 4WD.
No cab step: 1965 F100/250 2WD, 1966 F100 4WD. This trucks Styleside bed installed on 1964/66 F100/250 2WD, 1966 F100 4WD.
Old Jun 8, 2013 | 12:37 AM
1966Jacked4x4
Thank you. I forgot it should be a "wrong bed" and didn't know that 4x4s had the cab step. If you bought a 4wd new in 1965 was a 1965 f100 2wd styleside bed an option you could order?
Old Jun 8, 2013 | 02:01 AM
Alaskan66's Avatar
Alaskan66
Aren't you overlooking the most important part --"It is Black"
Details, gentlemen, details!!!!
Old Jun 8, 2013 | 04:15 AM
NumberDummy
No, 'wrong 1957/60' were the only Styleside beds available for 1965 F100/250 4WD, 1966 F250 4WD.
Old Jun 8, 2013 | 08:11 AM
schoo's Avatar
schoo
I did not think the wheels would fit in the bed that good
Old Jun 8, 2013 | 02:02 PM
NumberDummy
Originally Posted by schoo
I did not think the wheels would fit in the bed that good.
1957/60 'wrong beds'
Used on F100's with 15, 16 and 17.5" wheels.
Used on F250's with 16, 17.5 and 19.5" wheels.
Used on F350's with 16 x 5.5, 17 x 5.5 and 19 x 5.5" wheels.
The F350 bed is unique, as it's 9' long.
Old Jun 8, 2013 | 03:38 PM
Buzz44's Avatar
Buzz44
I blew the pic up and it looks like all the anodized trim is being held on with rusted sheet metal screw. I think it porbably is a true 65 4wd cab.Just has the trim added on from whatever CC truck he took the bed from. Makes me wonder what he did to the back frame after the cab to get the bed to line up. This is where I go into buyer beware mode. I would look that back half over real close.
Edit: I alway have to go back and take a second look. Something looks out of whack with that steering wheel and column. Cant put my finger on it. Gap is to big between the wheel and the blinker light switch bearing housing. Might just need the tube pulled up a little dont know.
Old Jun 8, 2013 | 08:41 PM
1966Jacked4x4
You can see the "Caribbean Turquoise" coming through under the black.
I think the money he wants for it is nutz. I am sure it has many many issues. Considering the area of Wisconsin that truck is from only has 2 months without snow. I can only imagine that its a rust bucket and is being held together with fiberglass.
Old Jun 8, 2013 | 08:43 PM
1966Jacked4x4
I just was trying to use it as an example to learn some more about the 4x4 slicks.
Curated Content Editor
Feb 10, 2018 01:19 PM
Ruffasacob
Mar 28, 2016 11:18 AM
oso503
May 17, 2014 08:02 PM
drguitarum2005
Aug 30, 2013 11:20 AM
tbm3fan
21
Sep 29, 2011 10:07 PM
