Is there any way to adjust the timing on a 89 bronco with a 302. The manual I have says it can't be adjusted on the TFI style ignitions. I figure there has to be some way to do it.
what does this spout connector look like? there is a harness going to the module on the dist., and there is also a short capped pigtail hanging off. Is the spout connector further up the harness?
"there is also a short capped pigtail hanging off."
that is the spout connector. It is a jumper that sends the SPark OUTput signal from the TFI module to the computer. Pull it and you can adjust the timing without the computer messing w/ it at the same time.
