Carpet/Floorpan Shape question
Old Jun 6, 2013 | 11:34 PM
PRUSue's Avatar
PRUSue
I just want to check if anyone else has had this problem. I ordered a replacement carpet for my 1973 F100 from Stock Interiors:
The choices for floorpan options are 2wd auto, 4wd auto, 2wd 4spd, 4wd 4spd. My truck was originally a 3sd 2wd, so I chose 2wd 4spd. Now that I have obtained the carpet, there is a large raised rectangular region in the middle of the trans hump. My floorpan has no such feature. In fact, the floorpan has a rectangular indentation in the middle of the trans hump. So when I place the carpet over it, there is no metal directly underneath it. I could place some think foam padding under it, but for ~$200 I expect a company to get this **** right.
Am I missing something? Is my floorpan weird or does everyone else have the same features? Alternatively, have people had problems with Stock Interiors parts not fitting?
Old Jun 7, 2013 | 02:33 AM
78_f800crewcab4x4's Avatar
78_f800crewcab4x4
*EDIT
Two types of front floor pans for F100-F350/ Full size Bronco:
2wd automatic (no hump)
Everything else (hump)
Old Jun 7, 2013 | 08:15 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Sometimes you'll see the choices as low or high rise center hump. The 3spd and some automatic 2WD have the low rise. Some auto 2WD, all 4 speed and all 4WD have the high rise center hump.
If the center hump is removable, it's a high rise. If the floor pan is one piece and not removable, it's low rise.
What you probably should have ordered is the auto 2WD carpet.
The two pictures below, both trucks are 360/C6 2WD. One came with the high hump and the other came with the low hump.
Like 78_f800crewcab4x4 said, you could always find a removable hump and put it on you floor pan, screw it in place and cover it with the carpet.
miottimouse
Jan 23, 2014 07:14 PM
oft
Sep 19, 2012 06:33 PM
voltson
Apr 10, 2010 06:36 PM
RM
Sep 15, 2002 10:08 AM
