I have a 76 f100 stepside and have a mess involving the wiring .
My problem right now is taillights and the fuse box. Are the brake lights and taillights on the same circuit? I have brake lights and no taillights. Any help would be appreciated.
I seem to have something weird going on.i was making progress checking circuits and gaing ground on it.Now I get nothing with test light on any circuit. Test light works engine starts turn signals work brake lights work but nothing tests with light as working.whats up?
Please accept my apology; my brain logged out for a few minutes. They are NOT on the same circuit; I gave you incorrect information and have since deleted my original post.
The brake lights are protected by the fuse panel; the tail lights are NOT. The tail lights are part of the running light circuit, which is protected as a whole by a circuit breaker internal to the headlight switch.
Do the rest of your running lights work (front parking lights, side market lights)?
What do you mean you're having a problem with the fuse box? What's the problem?
You need to be more specific about what "test out" means, and what the "circuits" and "things" are. I should be able to replicate your exact measurement on my own truck without any confusion. As of now I have no idea what you're doing.
If I take a 12 volt test light and touch it to the terminals in the fuse block the light lights up.Then for no reasoncant get any terminals to make test light work, but i have some things working.
