Sponsored by: Real Truck
unused connector
Old Jun 5, 2013 | 09:49 AM
delorenzomp's Avatar
delorenzomp
unused connector
2004 F350, behind the driver side front turn signal, a small black connector with a pink wire and a dkgreen/orangestripe wire, it is 'attached' (non-electrically) to the truck...what is/could it be used for? Thank you.
Old Jun 5, 2013 | 09:51 AM
MisterCMK's Avatar
MisterCMK
Do you have the electronic climate control?
That is probably the connector for the outside air temp sensor.
Old Jun 5, 2013 | 09:55 AM
delorenzomp
I don't believe so, it is simple HVAC, no outside temperature reading, no automatic thermostat, manual-set air-conditioning (by color range (blue/red), not with a temperature digit)...no fog lights (could it be for that?), could it be for upfitting (is that the correct term)??
Old Jun 5, 2013 | 10:30 AM
troverman's Avatar
troverman
My 2012 has a few unused connectors, too. Fog light connector is prewired to a plug with a blank in it below the radiator. The fog light kit contains the needed harness split. However, I have another blank plug below the radiator, not sure of its use. Of course your truck may be different. Maybe it was used for a sensor on the diesel version if your is a gas, or vice-versa.
Old Jun 5, 2013 | 10:44 AM
MisterCMK's Avatar
MisterCMK
Is the connector round?
Old Jun 5, 2013 | 10:55 AM
Shake-N-Bake's Avatar
Shake-N-Bake
I think you are on it....
It's likely the connector for the outside air temp sensor for trucks with the overhead console (Lariat trim).
Old Jun 5, 2013 | 10:58 AM
delorenzomp
The connector is flat, the engine is a gas V-10, manual transmission ...thanks for the responses...
Old Jun 5, 2013 | 03:12 PM
FarmingF250's Avatar
FarmingF250
Sounds like the right place for the resistor for day time running lights..at least on a 2K
Old Jun 5, 2013 | 03:30 PM
delorenzomp
it could be a resistor, because of the way it is attached I only ASSUMED that it was a connector, however, I do not have daytime running lights, are you saying that it's there anyway?
Old Jun 5, 2013 | 06:26 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Is it the wire for the outside temp sensor. There is no sensor hooked to it because you don't have auto climate control.
Old Jun 5, 2013 | 06:36 PM
delorenzomp
that seems to be the concensus, thanks to everybody wo responded to my question.
Old Jun 12, 2013 | 02:37 PM
FarmingF250
My understanding is if you don't have DRL, the connector is still there. My truck has DRL, but the resistor was removed and connector cut off.
Old Jun 12, 2013 | 02:41 PM
delorenzomp
I would have to remove a few things to really get at it if I want to see what it is, connector or resistor...thanks.
briangp
Apr 19, 2018 06:35 AM
kholz12
Jan 13, 2014 07:08 PM
DAVE67FD
Apr 13, 2007 02:14 PM
aurora_1
Dec 21, 2004 10:39 PM
