Power Steering Leak
Old Apr 19, 2014 | 08:38 PM
DrRoady's Avatar
DrRoady
Originally Posted by 50th ann
I did the same thing back in June of 2012 and its working fine. My cooler is about four times larger. Drive it a while and feel the aluminum line to see how hot it is. Mine is cooler now than it was before.
I did. It gets warm but not hot. I don't run over sized tires or anything so i think it will be ok. If it ever does get too hot there are a few larger sizes i can upgrade to.
Old Apr 20, 2014 | 02:50 AM
50th ann's Avatar
50th ann
Before I changed anything when the truck was all original the lines would be hot to the point that you could hold on to them but a few more degrees and you would have to let go or it would burn you. now that the cooler is in place the lines are warm but not as hot. I did double clamp mine for good measure.
Old Apr 20, 2014 | 09:52 AM
meborder's Avatar
meborder
something worth noting is that it is possible to over-cool the fluid as well.
'good and warm' is where you want to be, but 'cool to the touch' is probably not a good thing.
the system needs to build enough heat to help drive off moisture, or you could have corrosion problems, or starve the pump in very cold weather.
no different than engine oil. short trips are hard on the vehicle because the oil never gets a chance to warm up and builds up moisture.
Old Jul 14, 2019 | 08:57 PM
Lonnie Jr's Avatar
Lonnie Jr
Help please
I blew out the old cooler with my air compressor. I pulled the original rubber lines off the top of the radiator and tied them off just in case I every need them again. I did not seal the original rubber lines or radiator ports.
The new cooling coil has been in and working perfectly for quite a while now.
I did not want to disturb the air conditioning evaporator coil to fix the leak in the power steering cooling coil. Both coils are one unit and expensive I'm sure.
Sir i would like to know what cooler you used and any line modifications you may of done my expedition is leakingcst cooler would like to bypass original one
Old Jul 15, 2019 | 01:45 PM
50th ann's Avatar
50th ann
Power Steering Leak
I purchased an add on transmission cooler (the one use when pulling trailers) at a local auto store. It measures 10" X 5" X 1" thick both connections were on the same 5" end and it had four rows of tubing from end to end. I did double clamp the hose connections for safety (not sure of the pressures) and used fuel line to make the connections. It worked perfectly for years.
Old Jul 15, 2019 | 02:34 PM
Lonnie Jr's Avatar
Lonnie Jr
Another question
do you happen to know where you got it? Also does anyone know if the 2 hoses to ps cooler on condensor are the same size hose and what size they are please
Old Jul 20, 2020 | 08:38 AM
Tjm_Laf's Avatar
Tjm_Laf
did you ever get this information and if so can you pass it along please.
Old Jul 26, 2020 | 06:50 PM
Master Training's Avatar
Master Training
Pwwfff, I have the same problem with my car and i still do not have the money to fix it. I hope someday I can repair it.
Best Dump Cart For Lawn Tractor
ruger761
6.7L Power Stroke Diesel
24
Nov 14, 2014 03:12 PM
Otahyoni
All Things Towing
Nov 14, 2011 07:53 PM
61 uni
Feb 23, 2010 06:45 PM
patrickke
Apr 20, 2009 07:14 PM
devenish
Aerostar
Dec 14, 2004 03:13 AM
