Leaking coolant from timing cover
Old Jun 4, 2013 | 03:29 PM
flamesoldier's Avatar
flamesoldier
Exclamation Leaking coolant from timing cover
Ok i need massive help. I just revuilt a 292 y block and put radiator fluid in an gave it a start up. Ran well except for leaking from a bolt on timing cover its the bolt that also holds the timing pointer. I unbolted it and radiator fluid pour out like a stuck pig. Am i suppost to use sealing tape on bolt threads whats my problem?
Old Jun 4, 2013 | 04:42 PM
raytasch's Avatar
raytasch
Believe Nothing
Those bolts on the timing cover run into the water jacket of the engine. Drain the coolant, remove each bolt and put a good sealer around the end of the threads and reinstall said bolts. Torque to specs.
Old Jun 4, 2013 | 04:44 PM
flamesoldier
Wow that makes perfect sense
Old Jun 4, 2013 | 04:45 PM
flamesoldier
Do u think permatex high temp thread sealer will work
Old Jun 4, 2013 | 05:37 PM
oldmerc's Avatar
oldmerc
oldmerc
Use Permatex type 2 or Aviation .
fightlivefree
18
Jul 27, 2013 02:17 AM
1oldtimer
Feb 14, 2012 11:14 PM
Mayerstom
Nov 9, 2008 09:15 AM
maa139
Apr 14, 2005 06:28 PM
billabong132
1983 - 2012 Ranger & B-Series
May 6, 2002 09:34 AM
