power steering
Old Jun 9, 2003 | 09:08 AM
treb's Avatar
treb
power steering
99 ranger 2.5 I4 5 speed nam. 225-75-r15 liberator on/off road tires p/s works fine no leaks just seems to be a little hard to turn when turning at very slow speed & turning around ect. thanks for any imput. note i run 33psi cold am. meant man. line 1
Old Jun 11, 2003 | 01:31 PM
travisca's Avatar
travisca
power steering
hello, my Ranger is not lifted, but in my younger days I ran a full size chevy w/40's.. Yes it was hard to steer at slow speeds and when tire pressure was low... Large tires are very hard on the front end.. If you have full time 4 wheel drive, you may look into changing it to part time. Also keep it lubed and use urethane bushings where possible.. Change the fluid in the pump, depending on milage.. I changed my hoses to bradied stainless after I blew a hose.. Alos, I do not know the mechanical work-up of a ranger, but I up graded the pitman arm.. I hope this steers you in the right direction... Good luck... Travis
Old Jun 18, 2003 | 03:19 PM
treb's Avatar
treb
power steering
thanks for info on power steering travisca it helps treb
d.steyer
16
Dec 30, 2014 01:01 AM
HotRod 66 F100
26
Nov 7, 2012 11:52 AM
unclehan
General Automotive Discussion
Oct 17, 2004 10:35 PM
straightedge
Jun 5, 2004 09:22 AM
