Carter 1 barrel reassembly issues
i will begin by saying this: i have rebuilt some Motorcraft 2 barrels and a few Holleys, but never a carter 1 barrel.
So, last january, i parked my 1981 F150, 300/c6 2wd truck "Clyde" in a snow bank, swung open the hood, and unbolted the leaky, gunky 1 barrel. i took it inside, tore it apart carefully, and put it all in carb dip for 2 days. i pulled it out, put it on the large tray i have used to reassemble carbs, and went and got a carb kit and a few other tidbits.
Then life happened.
So, here we are at June. i pulled the tray down last week, carefully hand wiped everything clean, and went to reassemble.
I dont remember how to put the damn thing together.
I got out my manuals, no exploded views. i looked around online a bit, couldnt find anything. i have a new carb kit sitting here, i dont remember if it has an exploded view in it or not, i dont want to break the seal on it, because it then becomes "non returnable"
Can someone help me out?? it's time to get this truck up and moving again... i have an engine swap planned, but that is a year or two down the road.
Then life happened.
I bought a reman last year from National Carb, after discovering mine had been gooberized by the PO, two buddies, four cases of beer, and a herd of gerbils.
But - you can download the 24-page manual here, for $7.95:
Carter YFA Service Manual - Ford
here is a link with
some good info including videos. It should get you thru the situation..
Hang in there.
Carter YF & YFA
Hang in there.
Carter YF & YFA
Hang in there.
Carter YF & YFA
Hang in there.
Carter YF & YFA
Well, bad news sports fans....
i have discovered that the throttle blade shaft has wobbled out the base plate. that explains my horrible dirveability issues...
>whats my next move, gents?
I used to sell cores to a rebuilder supplier from Delaware. Some of the stuff I sold him was literally thrown together enough to look correct. All I can say is, I would never buy a rebuilt carb knowing what I sold the rebuilders.
I guess I need to go look at my collection of YFA carbs and maybe rebuild a couple.
ok guys, change of plans....
I'm looking for a mostly functional YFA carb to bolt onto the truck to get it running again. I am not expecting rebuilt, like new, or anything like that. I can tune it to work properly, no issue. can somebody hook me up?
i'm im trying to get the truck running again so that i can start driving it while ironing out the engine swap plans.... so the less cash outlay, the better.
i pondered just reassembling the outer parts, and putting all the screws, etc in the float bowl, stuffed with cotton *****, lol
pm me when you get details.
