I NEED HELP WITH PCM/ECM?
Old Jun 5, 2013 | 11:17 AM
Davepomrenke's Avatar
Davepomrenke
Originally Posted by trk98
Sorry i cant contribute to your thread but I had to ask. Thats really cool, i actually love that show and your brother and nephew and Cody are my favorite crew. Least amount of drama and all about business, and seemingly great people. Id do anything to work for them so if they need any help im your guy. Good luck with your question and sorry to be off topic.
No problem, getting that yellow element/metal is nothing but difficult as many poor, busted, flat broke wanna be miners find out when they come to Nome looking for millions. The weather was so bad here last year many, many dredgers went home flat broke and deep in debt.Cody could work a little harder, but he is still a great guy just likes to take to many vacations.
Just so all those high compression diesel owners out there know we run nothing but diesels here. Diesel is a little less expensive than gas and gas is right around $6.00 a gallon. We got chevys-6.2's, fords-7.3's, cummins, cats, Detroits, Isuzus, perkins, and ??? Almost everything Steve has is a diesel.
Old Jun 5, 2013 | 01:48 PM
clem1226's Avatar
clem1226
Originally Posted by Davepomrenke
Thanks Tugly,
Still wondering if anyone agrees with my chip supplier telling me my IDM is faulty and not his chip?
No I do not agree:
From everything you have stated my best guess would be it is the programmer. IE it runs with no chip installed, runs when you pull the chip.
I am wondering about something though and maybe this will open the question up a little more.
In stock form when the IPR sensor fails the PCM defaults to a preset table. Is that same table present when you are running a chip? What if the IPR sensor failed and the default fueling table wasnt present?
One other question
Do you have a check engine light when running now without the chip?
Old Jun 6, 2013 | 02:34 AM
Davepomrenke
Originally Posted by clem1226
No I do not agree:
One other question
Yes there is a check engine light showing.
Old Jun 6, 2013 | 02:42 AM
Davepomrenke
No I do not agree:
One other question
Yes there is a check engine light showing. In regards to the IPR (Injectiion Pressure Regulator) and the "table" I don't quite get what you want to know. The ECM is in stock configuration from the factory set to run AB code (Split Shot Injectors) for this early model 99. When you change from a split to a single shot it changes the timing slightly creating the "lope' which sounds like a iskerdarian race cammed funny car. It shakes only at idle, runs fine and has low EGT's ( Exhaust Gas Temperatures).
Old Jun 6, 2013 | 11:47 AM
clem1226's Avatar
clem1226
It would be a good idea to find out what is throwing the CODE to set the CEL.
I wasnt asking you specifically on the other issue just a general question hopeing maybe someone with the awnser would post up the info.
opps, I was refering to the ICP SENSOR not the regulator. In stock configuration with no chip if ICP Sensor fails then the computer begins fueling the engine based on a lookup table for ICP present in the PCM. When the sensor is working the PCM fuels the engine using the ICP (pressure) reading from the ICP sensor.
So my question was if the ICP sensor failed with the chip you where running was that default fueling table there to allow the engine to run? or did it just see the failed value reported from the ICP sensor and not fuel the engine?
It would be a good idea the find out what the CEL is all about, AC code sticks on stock programming....yeha they wil have a lopey idle but they shouldn't throw a code
Old Jun 6, 2013 | 01:40 PM
Davepomrenke
Chip problems
Thanks for the input Steve,
Personally I believe the the motor runs fine, even though it lopes. I think everything is working normally and the only problem is there are AC injectors receiving the information from all the systems, instead of stock AB's.
When the left bank died, I eventually pulled the chip after checking the left bank injector/glow plug harness, and the truck immediately ran fine except it had the lope. I just don't see how the IDM (Injector driver Module) would stop the chip from working as chip supplier says. If the IDM was bad, it would be bad with or with out a chip, that's the way I see it.
Dave
Old Jun 6, 2013 | 06:33 PM
jeffreyt's Avatar
jeffreyt
Well I guess that would depend on who wrote the calibrations. I have oil all over my ICP and am almost positive I'm stuck in the default. And that's with Php tunes. Guess we'd need Cody or maybe Dianne or Jody to jump in and tell us for sure, as I'm not a tuner.
Old Jun 7, 2013 | 05:44 AM
Tugly's Avatar
Tugly
For the sake of making this brief, I'll call the Look-Up Table a LUT. Just what we need, more acronyms.
There is more than one LUT for the ICP/IPR. There is the "Ah, I have feedback from the ICP... so I'll run normal" LUT. There is also the "Uh-oh, I have no ICP signal at all. I'd better run with the stock limp-home settings" LUT. No tuner in their right mind would want to mess with limp-home mode, so it's just sitting there until called upon.
I had to use mine not long ago when my ICP went bad. Here is what happens with an oily ICP - the oil in the connector changes the feedback voltage to read higher ICP than actual. This makes the PCM lower the IPR signal, giving you less oomph. If it was the other way around, the ICP sensor would read low ICP and jack the IPR up. Recapping (because this is big): If the ICP sensor said you had 1500 PSI ICP, but you really had 2200... the PCM would alter the Fuel Injector Pulse Width and timing for 1500 PSI and this could at the very least cause a lot of heat, smoke, and knock. No need to dwell on the worst-case on this, because the Ford (or IH) engineers thought ahead and configured the system to give less fuel and timing in the event of sensor failure or oil in connector. You don't think the 7.3L was their first rodeo, do you?
Tuning, loping idle, and AC sticks: I have stage IIs and a silky idle. The lope is actually very difficult to eliminate, if the tuner is not sitting in the truck. It can be done remotely with the "Ooops, too little. Ooops too much" procedure, but DP or a Hydra would make this so much easier because of the ability to email tunes. Here's the caveat, and my reasoning for bringing up a 100% truck: Say you get it dialed for a silky idle... but you have a flakey sensor in the truck. You finally discover the flakey sensor and replace it... now you have lope idle again. My truck has over 1/4-million miles and more than a decade in the elements, but "Stinky" is 100%. All sensors read in the green, everything functions as it should, and my tunes worked right out of the box... with the smallest of tweaks needed for perfection.
Since I have so much faith in the condition of Stinky, I had him live-tuned to dial my non-stock transmission and to "personalize" my tunes for my style of driving. Any grandpa could drive my 375 HP Daily Driver tune and never know the truck is jacked up on steroids... at least not unless he went diggin' for gold with his right foot. That's how a tuner should make his tunes... IMHO.
2 stroke man
Nov 20, 2008 06:49 AM
lightninglowe
Computer Chips & Tuners
May 31, 2003 06:14 PM
TexasTechsan
1997 - 2003 F150
Apr 25, 2002 12:43 PM
