That looks completely normal for one of these trucks with a stock motor, if you also get plenty of heat out of the core then there is nothing wrong with your truck.
What degree thermostat are you running? If your not kicking out any trouble codes I would not worry .At least your not running too hot thats the good thing .Some of those Ford factory gauges are not all that accurate .
