lights problem??????
Old Jun 2, 2013 | 10:23 AM
oldfordguy55's Avatar
oldfordguy55
this might have been mentioned and i missed it. i think your big problem is ground but when you fix that get you a heavy duty flasher and that will fix the quick flsh your getting when you hook up the trailer. i rented u hauls for years wiring was a daily thing what i always did was hook up the trailer drive around the block and then hook up my wiring and all was well.
Old Jun 3, 2013 | 06:28 AM
UZI-SUICIDE's Avatar
UZI-SUICIDE
If ya think auto wiring can be a mess...
I troubleshoot and repaired wiring on carnival rides for 11 years as well as installing new wiring rebuilding rides.. Those things take a beating and are "fixed" by pretty much anyone who is bored enough to start chopping wires.. and Europeans believe that 12 guage wire is universal I bet they wire thier houses with it, and the Italian manufactures must buy one huge roll of wire to wire everything with untill it runs out, there is no color code, ya get a ride with ALL one color wire... Then there are multi mechanical flashers to give rides different light patterns also "fixed" many times by many people over many years...
There are much better ways to try and make a living...
Old Jun 3, 2013 | 09:44 PM
JayzDaddy's Avatar
JayzDaddy
Changed ground 2~3 times. Same crap. Now i noticed when i pull my parking lights i loose brake lights. Im just going to connect it all back stock. I ordered in a harness that just plugs in to my stock harness. Here is a few pics of what i had and did.
Old Jun 3, 2013 | 09:45 PM
JayzDaddy's Avatar
JayzDaddy
Stock harness after rear plug
Old Jun 3, 2013 | 09:47 PM
JayzDaddy's Avatar
JayzDaddy
Brake and signal tie ins.
Old Jun 3, 2013 | 09:49 PM
JayzDaddy's Avatar
JayzDaddy
Looks like green is tied to brown but its not.
Gary Lewis's Avatar
Gary Lewis
I only get one pic, the one with you holding the plug. The back and forward buttons don't work for me so I can't see other pics.
Old Jun 3, 2013 | 09:52 PM
JayzDaddy's Avatar
JayzDaddy
Im starting to think its because i tied in after the plug where there were 2 black+pink & 2 browns. Maybe too much pull off of 1 of the browns tieing in a trailer off of 1 brown.
I dunno. Im just stumped.
Old Jun 3, 2013 | 09:54 PM
Gary Lewis's Avatar
Gary Lewis
I hate to say it, but I don't think your connections will last long. The rear bumper area is one of the worst environments around, with water, salt, dirt, etc in abundance. IMHO, crimp connectors should never be used in an automotive environment, and absolutely never back there.
I believe connections should be soldered and sealed with heat-shrink tubing.
Old Jun 3, 2013 | 09:55 PM
JayzDaddy's Avatar
JayzDaddy
Reload page. Should show 3pics. Im working off a phone and can only carry 1 url at a time from app to browser.
Old Jun 3, 2013 | 09:58 PM
JayzDaddy's Avatar
JayzDaddy
I understand. I was just using what i had on hand. Once it was all proven correct i was going to wrap it. But its comming back out.
Old Jun 3, 2013 | 11:38 PM
UZI-SUICIDE
I would go with the plug in deal.. No muss No fuss and if ya change rigs ya can take it with ya..
eknight
16
May 24, 2018 03:49 PM
phurst
Feb 1, 2018 11:27 AM
Myfreeford
May 3, 2012 10:13 PM
Scoop531
Feb 10, 2007 09:20 PM
Harlyred1
Feb 17, 2003 08:21 PM
