Pyro gauge ?
Old Jun 1, 2013 | 09:19 AM
arkredneck's Avatar
arkredneck
Pyro gauge ?
I just bought a 95 f450 that had a pyro installed the gauge bounces up and down about 200 degrees when your on the throttle when you left of the throttle the guages sits steady. They put the probe in the down pipe.. Any ideas what the problem could be?
Old Jun 1, 2013 | 09:43 AM
fordman67's Avatar
fordman67
Really to get a more accurate reading its better in an exh manifold. what brand of gauge is it? mine does not bounce.just moves depending on throttle.i have an autometer.
Old Jun 1, 2013 | 11:20 AM
arkredneck's Avatar
arkredneck
It's a autometer and I know it needs moved just havenot had the chance
Old Jun 1, 2013 | 11:38 AM
fordman67's Avatar
fordman67
I think i would get it moved and see if it clears up honestly
Old Jun 1, 2013 | 10:41 PM
oldbird1965's Avatar
oldbird1965
On my last trip of almost two thousand miles, I looked down once and mine was laying at the bottom. I thought, oh great, something else to fix. So I drove on guessing at EGT's towing against a head wind and looked down again it was working fine. Beats me what happened, hope it keeps working.
Old Jun 2, 2013 | 02:04 AM
Canadian7.3's Avatar
Canadian7.3
I have a autometer pyro that would spaz out, figured it was the backlight wiring was buggered, cut them and taped em off, no back light now but she reads perfect
Old Jun 2, 2013 | 07:28 PM
arkredneck's Avatar
arkredneck
Well I swapped injectors from my 96 which are 160/30 to the f 450 and the pyro gauge works great now
Old Jun 2, 2013 | 08:40 PM
oldbird1965
Did you 160/80's? Anyway, I wonder what the heck changed with the injector swap to correct the pyro?
Old Jun 2, 2013 | 09:20 PM
arkredneck's Avatar
arkredneck
It's got 160/30 in it. I did notice that one of the glow plugs wires under the valve cover had bare wire showing and I swapped that harness out for another but not positive that had anything to do with egt gauge
arkredneck
Dec 16, 2013 01:14 PM
snakedoc
Aug 21, 2012 11:01 AM
F350SD
Jan 3, 2007 10:04 PM
mstepchinski
Dec 2, 2004 11:03 PM
