Bronco II Ford Bronco II
rear drive shaft
Old Jun 9, 2003 | 01:24 AM
got_mud84's Avatar
got_mud84
Question rear drive shaft
i have a 84 bII 4wd and i have a 6 inch susp lift and a 3 inch body lift on it and the rear d-shaft is in a bind and i keep goin thru u-joints. any suggestions on how to fix it
Old Jun 9, 2003 | 07:16 PM
pat67shorty's Avatar
pat67shorty
rear drive shaft
lower the t-case and or inclrese the pinion angle of the rear end with shims.
Old Jun 10, 2003 | 03:48 AM
Hooked-on-4WD's Avatar
Hooked-on-4WD
rear drive shaft
Sounds like you need a longer driveshaft with a double Cardan joint. For more info, you can look into what James Duff Enterprises (at http://www.jamesduff.com/broncoII/drivetrain.html) offers. Some local performance shops may also be able to help.
Old Jun 11, 2003 | 12:35 AM
got_mud84's Avatar
got_mud84
rear drive shaft
i already shimmed the rearend but it didnt help i thiough tabout takin a grinder to the yolk and grinding a little off is that a good thing or no
Old Jun 11, 2003 | 05:09 AM
Hooked-on-4WD
rear drive shaft
Any grinding of metal off any part of a driveshaft risks throwing it out of balance. At 60 MPH a driveshaft can turn as fast as 3000 RPM That's probably faster than your engine is turning at that speed. So, balance is critical.
If your driveshaft has on one U-joint at each end, with that high a lift, it's bound to bind at the transfer case end. A Double-Cardan (double U-joint at the transfer case end) design is going to be your best solution.
If you can find a good one from a salvage vehicle at a local wrecking yard it's worth a try. If you do and IT doesn't quite fit right, you could see if the end yoke assemblies can be transferred to your original driveshaft. This may solve both your extended length and high driveshaft angle problems.
But beware of imbalance again! After you've gotten the drivetrain back together, drive slow at first. If you start to hear a low whine, or feel vibration in the floor that increases in pitch as you go faster, your driveshaft will need re-balancing. Some auto machine shops can balance a complete assembly for you for a reasonable fee.
Old Jun 13, 2003 | 12:26 AM
got_mud84's Avatar
got_mud84
rear drive shaft
ok thanks for the info ill give it a try and let ya know how it works
