Transmission question
Old May 30, 2013 | 10:12 PM
alchemist1's Avatar
alchemist1
So on the 74 f100, the issue with shifting from 2-3 is still there. The other day, I pulled in to get gas and put it in reverse. The truck sort of stuttered or shuttered and jerked backward. Giving it a little gas helped and then it was ok. It seems to be getting worse now. It's now almost as if the truck doesn't have neutral either. Putting the selector in either N or D will still have the truck going forward. Park works fine. Any ideas??
Old May 30, 2013 | 10:50 PM
SC'79's Avatar
SC'79
Did you check vac. modulator on side on transmission? Make sure vacuum line is on the nipple, mine came off on a road trip and i was having shifting issues. 75 cents new hose fixed it.
Mine was a 79 f150 and vac modulator was on passenger side dunno about 74 and f100, but the vac modulator itself can go bad as well. Check it out. good luck
Old May 30, 2013 | 11:05 PM
alchemist1's Avatar
alchemist1
Yup. Replaced modulator several months ago
Old May 31, 2013 | 06:12 PM
MikePacey's Avatar
MikePacey
Modulators frequently go bad. Have you confirmed that your shifter linkage is in correct position?
77beater150
Oct 17, 2014 10:57 AM
JosiahUSMC
Apr 30, 2014 01:59 PM
Lil_Bud_89
Jun 20, 2007 04:25 PM
bigfry
Apr 6, 2005 05:35 AM
grasmussen
Mar 11, 2003 02:00 AM
