Sponsored by: Real Truck
5.4 L lost power
Old May 30, 2013 | 02:59 PM
rickcaspari's Avatar
rickcaspari
5.4 L lost power
Hey Guys,
My truck has lost power in the past day or so.It will not go over 60 or 3000 rpm. I was trying to merge onto the interstate and couldn't get upto speed.It feels like what I would image a plugged exhaust would feel like.There are no service engine lights on.What should I check first?
Old May 30, 2013 | 07:39 PM
Mike189677's Avatar
Mike189677
What year??? It could be a clogged cat you can unbolt it and see if it acts normal except for being loud, pre 05 will not cause a check engine light with the cat unbolted.
Old May 30, 2013 | 09:28 PM
redford's Avatar
redford
FTE Leadership Emeritus
My 1995 F-150 did that. Over about 3000 RPM it would just lay down and go slower the more throttle I gave it. It was a clogged catalytic converter. To check it, disconnect your exhaust at the Y pipe and go for a ride. You'll know right away if you fixed the issue.
Old May 30, 2013 | 09:37 PM
JWC 3's Avatar
JWC 3
^^^ x 3 , sounds like a plugged cat . If it is ... find out why it is ! Missfires , lean run , oil burner ...ect . They do go bad on their own , but usually something helps them go bad . IME
Old May 31, 2013 | 08:49 AM
rickcaspari
Thanks for the input guys. The truck is a 2004. I replaced the fuel filter and air filters, They were due anyway. Didnt fix the problem. I tried to loosen the exhaust bolts , But they are rusted on. Sprayed them with PB Blaster and waiting on it to work . RICK.
Old May 31, 2013 | 09:09 AM
redford's Avatar
redford
Let us know what you find, Rick.
Old May 31, 2013 | 11:20 AM
r2millers's Avatar
r2millers
Having a bad cat reminds me of that commercial where the guy is pulling an anchor down the freeway. Happened to me years ago with another vehicle and slowing affected performance until I couldn't get up to speed on on ramps.
Then enough was enough.
joshr0886
Jun 8, 2011 10:57 AM
19704X4F250
1983 - 2012 Ranger & B-Series
15
Feb 7, 2010 08:08 PM
rlb454
Exhaust Systems
Feb 23, 2006 04:24 PM
MustangGT221
Exhaust Systems
Aug 22, 2004 12:16 PM
jrahn
Jan 21, 2002 10:32 PM
