Oil leak near starter
My truck has "marked it's territory" for month or so. When I would leave a parking spot there would be a 3" circle of oil towards the passenger side equal with the front axle. It is definately oil, not fuel because I got out to touch and smell it a couple times. It was tan colored and not red so I would guess it isn't ATF either. I only drive the truck a couple times a week so not much driving time has elapsed.
I hauled hogs last night and there was a trail of oil going into the shed. So, now it is time to get serious. I crawled under the truck and it appears to be coming from the general area of where the starter bolts to the engine block. I don't think it was coming from the pan because that area was all cacked up oil, not new fresh oil. I don't think it is coming out the drain hole at the back of the engine. There was an oil drip there, but I think it came from up above and ran down.
I pulled the truck up to the shop and pressure washed the top and bottom side of the engine bay. This should help me track the leack down a little better. What I am after is tips or common leaks in that area. I am never very good at finding these leaks and a little guidance can never hurt.
Clean the top of your motor with some simple green. Being sure to cover the alternator, power steering pump, and air cleaner, use a water hose to rinse it off after you have let it soak for a while. This should clean the top of the motor off to see where your leak is coming from. There is a weep hole at the back of the motor on the passengers side that will allow fluids to drain down. This will give the appearance of a leak below, when in fact it is on top. I would bet that you have a leak on top of the motor. Not hard to fix, just have to find it first.
I laid under the truck for about a minute and oil stated pouring out near the top of the starter. Pretty much a solid stream or very steady drip. The problem is I couldn't really tell where it was coming from.
Is the big hole in the block the drain that you mentioned? It wasn't dripping straight out of there, but surface tension could have been taking it over towards the block. Then it could be running down the block from there. The other problem I had was the freaking oil was dripping right on my face when I tried to look at it.
I have pressure washed the engine bay for a second time and I will look at it tonight after things dry out. I think I might take the TC inspection cover off before I try anything tonight. Thanks for the help!
About 8 out of 10 times the oil leak is coming from the top of the engine, the other 2 times it will be either the dipstick or oil cooler.
Look closely in the engine valley for any oil. Things that can leak up there include: HPOP, HPOP gasket, IPR, HPOP hoses or fittings, engine block to turbo pedestal, turbo pedestal to turbo, EBPV(on turbo pedestal), oil rail plugs(front and back of each head).
All of the leaks up top will drain down that weep hole, except for the oil rail plugs(you will have to reach back and feel for oil with you hand or use a mirror).
If it is leaking it is back by the turbo or the back of the heads. If it leaks on the back side of the head will it run up front in the valley?
Would it help to put the truck at a crazy angle? (ie nose up or nose down.)
Pretty much positive it is not in the valley. There was a trace of stuff in there, but it was probably just left over. I felt below the turbo (in the afternoon after the first washing) and didn't feel much besides oil and water. Then when I let it run there was no oil and water mix, just milky already mixed oil and water.
With an oil rail plug leak, it does not matter how you angle the truck. It leaks because of oil pressure.
It was leaking into the valley, but not filling it up like my fuel leak did. It appears to be coming from the back of the HPOP and running across the bottom of the fuel bowl. I have the area cleaned up again and I am going to have my wife start the truck to see if I can feel where the oil is coming from.
Ok...I am not sure I know where the HPOP is. I guess I always thought it was the thing before the piece of plastic that says Powerstoke. Then when I look at the HPOPs on Riffraff and Rock Auto they look nothing like that square thing.
My leak is coming from the back of the square thing and dripping back/towards the fuel bowl. So what is that square thing!?!
Scratch that...Google image search helped me find it lol
I saw a picture with the fuel bowl removed. The big square thing is the res and the HPOP sits behind it and under the fuel bowl (?) So maybe the oil is running right off the HPOP.
