Suspension Help
Old May 30, 2013 | 02:42 AM
mvbx's Avatar
mvbx
Suspension Help
Hi, I just purchased a 2002 Expedition, EB, 4.6 and the PO had it lowered 2 inches with 23" wheels. I got a flat and wanted to change the wheels to 22" to get a little more rubber on the road. 305/40/22 offset is +20.
I noticed that the wheels are closer to the fender on the drivers side than they are on the passenger side.
I am rubbing on the driverside but not on the passenger side. Is this normal or is there something wrong? I tried to search but haven't found the same question in my searches. Any help is appreciated.
Old May 30, 2013 | 03:35 PM
pdqford's Avatar
pdqford
Does it have the LLS?
Old May 30, 2013 | 03:44 PM
mvbx's Avatar
mvbx
It has eibach springs with beltech nitro drop 2 shocks...
Old May 30, 2013 | 07:06 PM
alloro's Avatar
alloro
It could be that the front end alignment camber setting for the right and left sides could make the difference, and/or worn ball joints. How much difference is there between the two sides?
Old May 31, 2013 | 01:07 AM
mvbx's Avatar
mvbx
Thanks alloro!
It's about 5mm or so, I didn't take an exact measurement. I know the springs have been on the car over 8 years. Do they need to be replaced as well? I think Ill have the camber settings checked.
Should I be able to fit 305/40/23 without any rubbing? Or is 285/40/23 the widest I can get in the front with a 2'' drop?
Old Jun 2, 2013 | 02:22 PM
alloro's Avatar
alloro
You're worried about 3/16 of an inch difference?
I think you can stop worrying about it, 3/16" is nothing.
Old Jun 2, 2013 | 02:49 PM
mvbx's Avatar
mvbx
LOl! i know normally I wouldn't but I was getting tire rub on that side....Trying various tires sizes and offsets this week, so will find out what works finally....thanks for the replies.
ryan73ford
Sep 2, 2018 11:55 AM
nmto0777
Mar 27, 2015 01:58 PM
1986Beast
Dec 5, 2012 10:15 AM
DetailerDave
May 16, 2006 02:05 PM
AtticusFinch1
Jan 1, 2005 09:26 AM
