mint 82 sitting
Old May 30, 2013 | 12:12 AM
thestinkyone's Avatar
thestinkyone
mint 82 sitting
So i just bought a mint 82 f150 . This truck has sat for a year or two and it was well maintained so far . I notice low to no oil pressure on the gauge wen it is running and a light ticking from the engine and even thou the temp gauge says
its normal temp i think its hot. So my plan is to drop the oil pan replace the oil pump. Is this a hard job on a 302 and what else would you recommend i do?
Old May 30, 2013 | 03:59 AM
oneowner83's Avatar
oneowner83
For small bucks I would buy a new oil pressure sender and see what it says, for starters. Its not wasted money, it'll serve you well for years.
Old May 30, 2013 | 10:38 AM
Gary Lewis's Avatar
Gary Lewis
I second that. It is far easier to replace the sender than the oil pump. And, beyond that, the gauges on these trucks are notorious for being just flat wrong. The Instrument Cluster Voltage Regulator is fraught with problems, and if it goes awry your fuel level, water temp, and oil pressure gauges will be wrong. So many of us run mechanical or electrical aftermarket gauges to find out what the temp and oil pressure actually are.
I would replace the sender first and if that doesn't show you have pressure then I'd install an aftermarket gauge(s) to see what the pressure is, long before pulling the pan and replacing the pump.
DeadBody
16
Dec 30, 2012 09:32 PM
alstieg
Jul 17, 2009 11:00 PM
SLE
Modular V10 (6.8l)
Jun 20, 2006 12:08 PM
85f-250-460
Jun 26, 2003 02:56 PM
fishingboy
Oct 7, 2002 06:23 PM
