Front end work
Old 05-30-2013, 08:23 PM
AXracer's Avatar
AXracer
AXracer is offline
Before you retighten the U bolts (are the nuts bottoming out on the threads with the thinner springs? Did you replace them with new ones with longer threads?) or have it aligned, slip in a pair of tapered caster shims oriented so the top of the axle tips back more. You definitely need them with leafs removed. That alone will make it steer better.
Nbing
19
06-14-2018 04:50 PM
Golden Helmet
12-06-2013 08:00 PM
Copedawg
60
05-30-2011 02:35 PM
wulleebullee
08-08-2010 06:33 PM
wicat3
08-21-2009 06:49 PM
Quick Reply: Front end work
