1996 cc refurbish/psd swap
I picked up a 350 crew cab last year with no motor, used to be a 460. I finally started tearing the thing apart recently. What was going to be a quick motor swap somehow is becoming a cab off restoration lol. I am hoping to have this back together and running by the first weekend in august so I can drive it to Carlisle Trucks, we will see how that goes...
If the pic links ever stop working, everything should be in here:
1996 Cc Rebuild - Psd Swap Photos by coreylasalle | Photobucket
When I got it last fall
[IMG]<a href="http://s1081.photobucket.com/user/coreylasalle/media/fte/1996%20cc%20rebuild%20-%20psd%20swap/73260_562228420603_1280689034_n_zps2c217fa3.jpg.ht ml" target="_blank"><img src="http://i1081.photobucket.com/albums/j359/coreylasalle/fte/1996%20cc%20rebuild%20-%20psd%20swap/73260_562228420603_1280689034_n_zps2c217fa3.jpg" border="0" alt=" photo 73260_562228420603_1280689034_n_zps2c217fa3.jpg"/></a>[/IMG]
Front clip off
[IMG]<a href="http://s1081.photobucket.com/user/coreylasalle/media/fte/1996%20cc%20rebuild%20-%20psd%20swap/IMG_20130525_114520_zps6539631d.jpg.html" target="_blank"><img src="http://i1081.photobucket.com/albums/j359/coreylasalle/fte/1996%20cc%20rebuild%20-%20psd%20swap/IMG_20130525_114520_zps6539631d.jpg" border="0" alt=" photo IMG_20130525_114520_zps6539631d.jpg"/></a>[/IMG]
Engine and tranny out of donor truck, along with all other good parts
[IMG]<a href="http://s1081.photobucket.com/user/coreylasalle/media/fte/1996%20cc%20rebuild%20-%20psd%20swap/IMG_20130422_182933_zpsea920e7e.jpg.html" target="_blank"><img src="http://i1081.photobucket.com/albums/j359/coreylasalle/fte/1996%20cc%20rebuild%20-%20psd%20swap/IMG_20130422_182933_zpsea920e7e.jpg" border="0" alt=" photo IMG_20130422_182933_zpsea920e7e.jpg"/></a>[/IMG]
My dog guarding the zf6 I recently picked up for a different project lol
[IMG]<a href="http://s1081.photobucket.com/user/coreylasalle/media/fte/1996%20cc%20rebuild%20-%20psd%20swap/IMG_20130421_134120_zps5d5e75e1.jpg.html" target="_blank"><img src="http://i1081.photobucket.com/albums/j359/coreylasalle/fte/1996%20cc%20rebuild%20-%20psd%20swap/IMG_20130421_134120_zps5d5e75e1.jpg" border="0" alt=" photo IMG_20130421_134120_zps5d5e75e1.jpg"/></a>[/IMG]
Front clip off
Just need the motor mounts for the diesel, 4 bolts each, the holes are already in the gasser cross member. the gasser motor mounts have 3? bolts on the pass side and 2 and 3 or 4 rivets on the driver side that i ground out. I'm not sure if that is the case with earlier gas cross members though , pre psd era?
Probably not, just clean it up. Maybe something with the fuel bowl, at least a gasket kit. my funds are limited as well. My biggest concearn is keeping the truck in good shape. I have por15 for the frame, and I might get grey por 15 for the bottom of the cab.
Mainly depends on your pricing for fittings, the pump, and wiring.
You can buy a wiring kit...pricey, but makes installation a breeze.
I will have to actually calculate, but with the wiring kit, filters, bases, pump, fittings, regulator and all Im about $375.
The wiring kit with OPS and stuff is $120+shipping IIRC.
[IMG][/IMG]
Front clip off
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Front clip off
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
