Brake HELP ASAP Please
Old May 27, 2013 | 09:53 PM
Sharla Clark's Avatar
Sharla Clark
I have a 71 Ford with 79 running gear, and when I push on my brake pedal it stays to floor when the truck is on or off. When bleeding there is fluid just not a bunch of pressure. Can anyone please help me why? I have replaced everything and it still is doing the same damn thing.
Old May 27, 2013 | 10:29 PM
JWC 3's Avatar
JWC 3
Are your rears adjusted properly ,no leaks , proper fluid ? Try gravity bleed . And , What all did you replace ?
Old May 27, 2013 | 10:56 PM
wilcam47's Avatar
wilcam47
did you adjust the push rod? Did you change the booster?
Old May 28, 2013 | 11:04 PM
Sharla Clark
How do you adjust the push rod? It has new lines, a valve, and all the brakes have redone. It has brakes but the pedal will not come back up. I am clueless..
Old May 29, 2013 | 09:04 AM
teds74ford's Avatar
teds74ford
You shouldn't have to, but when you buy a booster, it has a little "L" paper to verify rod height. It looks like a mini carpenter's framing square.
Just curious, how good of a bleed have you done? I would guess you have too much air in it. I would try a rebleed and then worry about other things.
Old May 29, 2013 | 09:11 AM
skidoodave's Avatar
skidoodave
Sounds like a bad master cylinder.
Dave145
38
Dec 21, 2017 12:29 PM
Jrobole
Jul 5, 2016 11:33 AM
mountain dewd
18
Dec 4, 2015 10:22 PM
rmalottwtes30
Apr 17, 2008 10:28 PM
Ed's1990
13
Sep 7, 2004 09:13 AM
