Weird Power loss
Old May 27, 2013 | 09:18 PM
vtjvt's Avatar
vtjvt
Weird Power loss
Last friday I was pullling my 4.000 pound camp trailer up to or camping spot. All the way up the freeway I was able to keep a good 60 to 70 miles an hour. in 4th gear between 2500 and 3000 RPM. On the last 30 mile stretch. (Mostly flat) I could not get over 55 mph in 4th gear and pedal to the floor. Then it cleared up and ran fine all the way home. I know the cat is not plugged. (don't ask just trust me) I forgot to mention it backfired twice on the way up.. Any ideas?? Truck is a 1988 F250 4x4 7.5 liter 5 speed. Everything is stock except the unplugged cat. I am leaning towards exhaust??
Old May 27, 2013 | 10:10 PM
DBGrif91's Avatar
DBGrif91
Carbed? FI?
If FI, pull the trouble codes as that's usually a good place to start.
If carbed, it's possible the float stuck for a time, but with your foot on the floor and a continuous flow of fuel, it broke free again.
Old May 27, 2013 | 10:17 PM
vtjvt's Avatar
vtjvt
It is fuel injected. I ran the koeo and no codes I will pull the running codes after work tuesday. It's funny because it ran fine. nice and smooth, didn't heat up or anything. just felt like I was dragging a strip mall behind me.
Old May 27, 2013 | 10:25 PM
1993_f350_2013's Avatar
1993_f350_2013
im gonna be that guy and ask how do you know your cat is not plugged?
Old May 27, 2013 | 10:33 PM
vtjvt's Avatar
vtjvt
Because everything kinda fell out last fall.
Old May 27, 2013 | 10:39 PM
1993_f350_2013
ohhh i see! that dang rust is pretty good at puttin a pipe back in its place!
Old May 28, 2013 | 10:57 AM
Bad Bad Leroy Brown's Avatar
Bad Bad Leroy Brown
I have been having an intermittent issue that sounds very similar. Sometimes no power to get past 55 in 4th gear pulling a camper, and even unloaded it feels sluggish sometimes.
Due to the intermittent nature, it seems it can't be a hard item like spark plugs or something. Maybe timing advance acting up? Maybe getting EGR when it shouldn't be? An intermittent vacuum leak might cause either of those. My koeo revealed nothing as well.
Old May 28, 2013 | 06:09 PM
vtjvt's Avatar
vtjvt
OK no codes either koeo or koer, Kinda stumped.???
Old May 29, 2013 | 08:49 AM
Bad Bad Leroy Brown
Due to the backfire under heavy load (pulling the camper up a hill), I bet it's a fueling issue.
Wait, was your fuel tank low? Is the hill steep enough you might have been starving the fuel pickup in the tank > Lean condition > back fire > back on level ground and now its fine?
Old May 29, 2013 | 09:14 AM
subford's Avatar
subford
Have you bypassed the fuel reservoir?
If so that will cause it on hills.
Old May 29, 2013 | 02:50 PM
Island'r's Avatar
Island'r
Whens the last time the fuel filter was changed?
Old May 29, 2013 | 06:03 PM
vtjvt's Avatar
vtjvt
Tank was over 1/2 full, Nothing is bypassed and the filter was changed last fall. I am going to change the filter again this weekend, when it backfired was when I was slowing down. Once for a sharp turn and the other time when pulling off the main road onto the dirt. When I couldn't get above 55 I was on a almost flat straight road.??
Thanks for all the ideas so far guys. I really appreciate it>
Old May 29, 2013 | 07:31 PM
rla2005's Avatar
rla2005
Please define no codes. At the very least you should have gotten the System Pass code of 11/11 for KOEO, the same for CM display and once again for the KOER tests. Anything less means you did not pull the properly. This can be caused by corroded pins on the diagnostic link, a bad PCM and a few others.
Old May 29, 2013 | 07:53 PM
vtjvt's Avatar
vtjvt
Yea I got the all good. 11/11 codes, I tried with my scanner and the dash display.
Old May 29, 2013 | 10:37 PM
rla2005's Avatar
rla2005
Thanks for the clarification
