Ringing front drive shaft
Old May 27, 2013 | 07:24 PM
Per4mance's Avatar
Per4mance
Was driving down the road with the windows wide open cause it was a great afternoon, and hit a couple bad bumps and hear a ringing, clanging sound from under the truck. Got it home and went under with the creeper and stated to ck things out. for some reason I happened to turn the front drive shaft and sure enough there is something rolling around in there. Any of our dealer guys hear of this? The only way I know to fix this is either cut the shaft open or replace it
Old May 28, 2013 | 07:03 AM
Monster-4's Avatar
Monster-4
Are you sure it's not from the slip-joint?
Old May 28, 2013 | 07:59 AM
Per4mance's Avatar
Per4mance
Yep, you can turn it and hear it rollin around in there. That shaft set up is about $ 350.00 shipped
Old May 28, 2013 | 10:10 AM
Monster-4's Avatar
Monster-4
Possible when the end where being welded on the shaft something fell inside. Maybe some slag. If it really bugs you I would take it to a drive shaft shop and have them cut off an end and see what's inside and re-weld the end on. Probably be cheaper.
Old May 28, 2013 | 10:16 AM
Per4mance's Avatar
Per4mance
I was thinking the same thing
aceltx09
Aug 10, 2010 07:30 PM
aceltx09
Aug 4, 2010 08:29 PM
73-79P/ULover
Feb 14, 2004 06:19 AM
F100DREAM
Sep 22, 2003 06:28 PM
