oil pump shaft
Old 06-09-2013, 05:55 PM
1960fordf350's Avatar
1960fordf350
1960fordf350 is offline
oil pump shaft
Just recently put head gaskets on my motor. New oil pump also. I ran the pump using a drill and had good pressure. Put in the distributor and started it. No oil pressure at all. I can pull distributor and run oil off shaft with a drill, but none with distributor in. I also pulled oil pump and re-installed. Is there any different length shafts cause I changed the pump?
Old 06-11-2013, 03:39 PM
charliemccraney's Avatar
charliemccraney
charliemccraney is offline
There is not a different length shaft. Is the distributor rounded out?
Did it work before you replaced the head gaskets and pump?
Old 06-11-2013, 09:51 PM
46yblock's Avatar
46yblock
46yblock is offline
The end of the distributor shaft may not have dropped down onto the oil pump drive shaft. The pump shaft may have a little wobble. When inserting the dist. make sure it is seated onto the block surface. If it wont drop fully into place a bump of the starter, or manual advance of the crank may help.
Old 07-16-2013, 08:04 PM
The Horvaths's Avatar
The Horvaths
The Horvaths is offline
Did you replace oil pump drive shaft? Apparently a batch of new ones were assembled, packaged, and sold with the retaining washer on the wrong end.
Old 07-17-2013, 10:28 AM
1960fordf350
Sorry didn't get back sooner. Work and vacation has taken all my time recently. I bought a new shaft, and also bought a shaft for a 390. They are both the same size, but the 390 shaft is 1/4 in longer. When I originally pulled the distributor, it had no seal and was pucking oil on top of the engine. The gasket set came with a big rubber tapered seal I installed in the hole. I think it raised the distributor enough to lose contact. With the filter off I could crank the motor one time and pump oil. Next turn of the crank and nothing. Towards which end does the retaining washer go?
Old 07-17-2013, 03:03 PM
The Horvaths
It goes in from the pump ("bottom") end and the washer/retainer keeps the shaft from pulling out of the pump drive coupling when the distributor is removed. See the second post here:
Y-Block 292 oil pump drive shaft question - The Ford Barn
The one I bought two months ago was wrong.
Old 07-17-2013, 03:52 PM
charliemccraney
If I'm not mistaken, the distributor does not use a gasket.
I don't use one but my distributor is a Motorcraft which has an o-ring.
Oil can also be coming from the valley pan and I think a bolt hole in the intake flange at the back of the head. I think that bolt hole goes to a pushrod hole but I can never remember.
If it's actually puking from the distributor, I think there is some other issue.
alconk
11-02-2008 01:04 PM
marks69
16
08-10-2008 07:53 AM
pokerpuller
05-15-2006 02:47 PM
SasquatchF-250
15
05-17-2005 12:38 PM
jimbo001
02-13-2004 10:42 PM
Quick Reply: oil pump shaft
