1978 - 1996 Big Bronco
no speedo
Old May 26, 2013 | 11:11 AM
rwenzel94's Avatar
rwenzel94
no speedo
i have a 1994 bronco with 351 and a4od. speedo doesnt work at all and tranny shifts hard at 3000. changed rear speed sensor. what else could it be? thank you
Old May 26, 2013 | 11:50 AM
greystreak92's Avatar
greystreak92
Welcome to FTE and the Big Bronco Forum. We will do our best to get you the most accurate info we can.
If you have replaced the VSS and you still have issues, have you cleared fault codes? Have you run a KOEO and KOER test to determine if the computer shows any other faults?
Old May 27, 2013 | 05:13 AM
rla2005's Avatar
rla2005
Welcome to FTE! Could you please define "speedo doesnt work at all" Does that mean the needle never moves and/or the odometer is blank? The repair could be significantly different depending on the failure mode.
A minor correction: there is no "a4od", the proper name is E4OD (Electronic 4-speed Over Drive) transmission.
Old May 28, 2013 | 12:51 PM
Kemicalburns's Avatar
Kemicalburns
i suspect he issue is with your ABS control module. you may have to search but there is a process for jumping a series of pins on that plug to bypass the module. i had this very issue on my 94. once you install the jumpers drive it around and tranny should be back to normal along with the speedo.
you must then find the same model abs module (94 bronco). keep is posted.
Cody333
Dec 16, 2016 05:34 PM
hooptytank
Aug 25, 2015 09:05 AM
Fordv10guy
41
Apr 20, 2013 01:20 PM
joelswork
Nov 4, 2010 11:07 PM
