Lpop diag help needed
Old May 25, 2013 | 10:49 AM
powerstrokeon40s's Avatar
powerstrokeon40s
Recently purchased a 6.0 with engine front cover off. Putting everything back together with 2 new batteries and installed fomoco oil filter and cap. Oil is new and full. Did 4 15 sec. Crank cycles and new oil filter is bone dry still. Wondering how the lpop system works as well as how to test it. Im thinking maybe from the front cover sitting the regulator right underneath the lpop is stuck. Could that be an issue?
Old May 25, 2013 | 02:38 PM
BLADE35's Avatar
BLADE35
YES
Odds are your engine needs to come out that's why it got sold
Normal culprit is Lifter Bearing taking out the LPOP gears
How did the LPOP Look????
Old May 25, 2013 | 02:49 PM
powerstrokeon40s
Lpop had a few small knicks on it. I would still think with a small mark on the lpop it should bring a little oil up to the filter. Going to remove the regulator under the lpop and see if its stuck or something. Doing research i see the lifter bearings are a common thing to to go and ill probably have to pull and rebuild but i just wanted to try a put back together to figure it out for myself and start from scratch instead of having no idea what is going on.
powerstrokeon40s
May 18, 2013 01:14 PM
GTOBRIAN
Apr 21, 2013 02:05 PM
bigNickN
Oct 27, 2012 06:06 PM
FERacing66
18
Apr 23, 2004 07:51 AM
460powerhouse
Oil & Lubrication
15
Mar 25, 2004 07:48 PM
