firewall work
Old May 24, 2013 | 12:48 PM
jniolon's Avatar
jniolon
old and in the way
firewall work
finally got a day to work on the truck with my body man. We started smoothing the firewall... cut and welded in filler panels.. and the first wipe of kittyhair... to be followed by fiberglass... then grind,grind,grind... sand,sand,sand ...then all purdy I hope.... end of the first session (2 hours)
j
Old May 24, 2013 | 01:20 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Why / where are you going to fiberglass? Looks very clean now!
Old May 24, 2013 | 04:17 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Nice to see some progress! thats gonna look pretty danged good.
Keep at it
Bobby
Old May 24, 2013 | 04:39 PM
52 Merc's Avatar
52 Merc
I'm with ross. What/why are you going to use fiberglass over the metal? It certainly isn't SOP for bodywork. Even kitty hair is a bit overkill, imho. What are you looking to gain? I'm assuming you're welding your patches in solid?
Old May 24, 2013 | 04:48 PM
jniolon's Avatar
jniolon
old and in the way
there were a bunch of holes in the firewall..... I tried filling them but ended up blowing more in than I fixed... even with a low amp welder. I got them all filled and could have wiped over them to cover but I decided I wanted it smooth without the ridges and bumps... the only indent will be the transmission tunnel when it's complete
Patches are tacked in every inch or so, then ground smooth, then covered.. kitty hair holds up better than glass for the base then very light coat of glass for finish...
Bobby understands, don't you Bob... you're my kind of crazy
j
Old May 24, 2013 | 05:35 PM
AXracer's Avatar
AXracer
Why did you not weld them in solid? No kitty hair needed and no later cracking.
Would have taken maybe another hour of welding (mostly waiting for tacks to cool), bet you spent a lot longer than that covering the unwelded edges. Also paint should have been ground back before welding. Yes, it is possible to MIG weld thru paint, but never a good idea (unless it is weld thru primer). Judging from this, I'd have to guess blow thru issues were more improper technique than amperage. Anyone contemplating similar, please read my MIG welding tutorial first.
Old May 24, 2013 | 08:42 PM
bobbytnm's Avatar
bobbytnm
j
LOL...I've chased my share of holes around. After I was done patching my firewall it looked lilke a porcupine blew up on the inside of my truck.
Recently I was helpping my buddy, we were cutting down a 56 Packard dash to fit into a 58 Packard. I was filling in some patch panels on the edges, things were going great when all of a sudden.....whoosh I had a blowout which grew, and grew, and grew (I sure could have used a chunk of copper that night)
A frosty beverage or two and quite a bit of teasing from my buddy and I got it looking good
Bobby
Old May 27, 2013 | 09:14 AM
cmoritz's Avatar
cmoritz
I don't see any heater hose /A/c line holes..I wish I'd spent more time fitting my evap/heat unit at the stage your at, ..looking good!
koolhandluke
Feb 21, 2011 04:56 PM
ssj7kids
29
Aug 7, 2008 01:05 AM
65fordguy
13
Mar 21, 2008 06:17 AM
jack71
Jan 29, 2006 06:54 PM
wblevins
Paint & Bodywork
Feb 25, 2002 02:05 PM
