Heavy duty crank
Old May 23, 2013 | 07:57 PM
mytbtruck's Avatar
mytbtruck
Heavy duty crank
Need a heavy duty crankshaft for your flattie. This is displayed outside the Caterpillar dealer in West Columbia SC.
Old May 23, 2013 | 08:07 PM
4tl8ford's Avatar
4tl8ford
That could work
Old May 23, 2013 | 08:26 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Day-ummm... From a locomotive?
Old May 23, 2013 | 08:34 PM
JWC 3's Avatar
JWC 3
I could use that in my next dirt track build !
Old May 23, 2013 | 08:36 PM
mytbtruck's Avatar
mytbtruck
Don't have any idea what it goes in. Definately eight cylinder. Has a main bearing between every rod.
Old May 23, 2013 | 08:42 PM
irondragon79's Avatar
irondragon79
There were engines I use to work around the natural gas pipeline business that were the size of semi trailers. These are natural gas burning engines that they use to pressurize the natural gas in the pipeline to relay it up the line to the next station. The cylinders and crankcase were considered "confined space entry", meaning they were large enough for someone to fit into (think cylinders were close to 3ft)... I wish I had a picture of a connecting rod.. They were 6ft easy
Old May 24, 2013 | 09:37 AM
tinman52's Avatar
tinman52
Welder User
Cat makes some huge diesels for generators......similar to loco engines, local hospital has one.
I was at the metal scrapyard once, they had a V16 diesel engine block there you could stick your head and shoulders inside the bore.....
Makes our old flatheads look kinda like a toy.
Old May 24, 2013 | 12:15 PM
arctic y block's Avatar
arctic y block
Don't they know a crank will warp stored on it's side like that???
Old May 25, 2013 | 09:22 AM
oscajo's Avatar
oscajo
How about this one.
Ford Truck Enthusiasts Forums - oscajo's Album: Garage - F1 - Picture
Old May 25, 2013 | 10:15 AM
52 Merc's Avatar
52 Merc
For its size, it seems to have a fairly short stroke. Just an observation.
Old May 25, 2013 | 10:33 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Looks like 5 - 6", agreed that's not a lot. But for say a 6" bore, that works out to 4500+ c.i.!! Not much in the way of counterweights, either.
Actually, I wonder if it's from a 2-stroke Detroit V16?
Old May 25, 2013 | 10:39 AM
fabmandelux's Avatar
fabmandelux
FTE Remembers
That's just a small crank. How about this one!
The World's Biggest Crankshaft
Old May 25, 2013 | 11:25 AM
oldmerc's Avatar
oldmerc
oldmerc
Why would a Cat dealer have a Detroit Diesel Crank out front ?
Old May 25, 2013 | 02:12 PM
mytbtruck's Avatar
mytbtruck
Look at those midgets around it. Size matters!!!
bigtexan99
Feb 8, 2008 09:20 PM
Red Star
Ford vs The Competition
Jan 23, 2008 03:36 PM
RangerTuff05
Jan 18, 2007 11:38 AM
