EEC-V Location on 1995 Ranger?
Old Jun 8, 2003 | 02:07 PM
cbush75896's Avatar
cbush75896
Talking EEC-V Location on 1995 Ranger?
Hello! I have a 1995 Ford Ranger and am tryinmg to locate the EEC-V system on it. I have a Haynes Book that is no help at all. It lists the location for 1993-1994. Please Help.
Old Jun 8, 2003 | 02:33 PM
Bob Ayers's Avatar
Bob Ayers
Welcome to FTE!!!!
The PCM is in the firewall on the passenger's side. You will see a
huge connector going into it.....
Old Jun 8, 2003 | 03:27 PM
cbush75896's Avatar
cbush75896
I also need to know where the the test port for 1995 Ranger is located
Old Jun 8, 2003 | 03:51 PM
Bob Ayers's Avatar
Bob Ayers
On my 1999 is't located at the bottom of the dash panel below
the steering column.
Old Jun 8, 2003 | 07:15 PM
Ken00's Avatar
Ken00
Bob is correct.
Old Jun 8, 2003 | 07:55 PM
FTE Ken's Avatar
FTE Ken
All Rangers and Explorer's after 1994 have them on the top-center of the firewall, offset slightly to the passenger side.
1996 and older F-series had it on the driver's side under the dash by the emergency brake. 1997 and newer F-150 has them on the passenger side behind the kick panel while the 1999 and newer Super Duty has them on the driver's side.
If you need a photo let me know....
Old Aug 4, 2003 | 03:41 PM
bluesoftail's Avatar
bluesoftail
Would this be inside, or out? A pic would be great.
Thanks
Old Aug 4, 2003 | 08:21 PM
wptski's Avatar
wptski
Are you sure that it's a EEC-V on a 1995 Ranger not a EEC-IV? I thought that the EEC-V wasn't used till 1996. I think a sticker inside the engine compartment will tell you if it's OBDI(EEC-IV) or OBDII(EEC-V).
Old Mar 26, 2007 | 07:42 PM
phost's Avatar
phost
I'm confused on the EEC-IV vs EEC -V on the 1995 Ford Ranger as well. If it's the EEC-V, I should be able to use my normal code reader. However, as was said earlier, I have a Haynes manual and I think it's confused. 1996 is when EEC-VI became standard, So the location is either inside under the passenger side of the dashboard or outside on the firewall???
Some good new is that the manual said it was a OBD II, so it should be a simply plug on my normal, digital reader.
Old Mar 26, 2007 | 08:08 PM
fflintstone's Avatar
fflintstone
NO!!?? Please say it isn't true.
Old Mar 26, 2007 | 08:11 PM
Rockledge's Avatar
Rockledge
Welcome.
1995 was a transition year for Rangers, which is another way of saying that they are considered OBD-II (EEC-V) even though they are not "fully compliant". Because of this, some people with a '95 Ranger have had trouble pulling codes. Some OBD-II code-readers seem to work on them, some don't.
I believe you will find an OBD-II-like connector under the driver's side dash of your '95. It might have a little cover over it.
Try doing a search, you'll run across some other relevant threads on the subject.
Old Mar 26, 2007 | 08:18 PM
phost's Avatar
phost
thanx, Rockledge. I think you're right. I was under there a bit but probably not with upside down enough - on my back, unable to breathe with stuff flowing backwards into my sinuses, U know, the usual the required position!
Unaffiliated
Oct 13, 2016 09:13 PM
khruldavid
Nov 26, 2014 07:54 AM
Kappa505
16
Jan 18, 2013 05:25 PM
84Fordvan
22
Jan 22, 2011 10:33 AM
broncomutt
Electrical Systems/Wiring
Feb 9, 2008 08:19 PM
