I'm currently running DJM 4" lowering (shackles/mounts) in the rear, and blue oval 2" drop springs up front. I know I can do the 3" DJM dream beams which I am torn on only because I'd like to drop lower. I know I can roll onto the axle flip and grab another 6" out back and get down to -10" out back, but that doesn't help me out front knowing I can only get another 3" putting me at 5"/10" which won't line up very well.
Is there any other options up front? I'd like to see 7-8"/9-10" overall.
If there's no way to do any further up front i'll end up c-notching and doing dream beams and ending at 5"/7".
Attached is the pic of the truck as it sits - i got her as a rust bucket for about 1k a few years back and threw a 302 out of a fox body stang, a 9" out of a e-van and sprayed in a makeshift room made of dropcloth in the garage, and lots of welded in panels I just want to see those tires tuck and throw some whitewalls on her. I've got access to a dodge 12v diesel i've been toying with the idea of as well, and i'm sure that weight would gimme a little drop! lol.
Do you know if any of them are straight up put in place and weld in? Or are they modify to fit? It's a lot of money to drop if its not a straight up replacement.
IIRC, Fatman's is designed for the application. The others are custom-fit but in reality anything that is not stock is a custom application and these companies assume since you're already cutting and welding, that you're not afraid of some fitting.
Don't expect anything to be a "straight" weld-in job.
I expect custom fitting, but I also have no intention to spend 2k if it takes making custom brackets and all sorts of craziness to get it on. I don't mind fitting, bending, working stuff to match, heck thats expected in almost anything. But for 2k it better be close
OK .. ya made the expectation of "straight in" sound unrealistic.
Based on my understanding, I'd go with Fatman Fab's 60.5-inch wide hub-to-hub system. The Welder series requires more cutting and fitting since it is really a generic kit requiring more of your own engineering.
