Lowering an E350 - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Lowering an E350
Old 10-18-2016, 12:56 AM
Foster1447
Foster1447 is offline
Foster1447 is starting off with a positive reputation.
Lowering an E350
Hello,
I just bought a 2012 E350 and I'm new to the forum. I want to lower the front about 3 inches and the rear about 5 inches. I have searched around and have not found any good videos or posts that help. Maybe I am not entering the correct search words. I have found the airbagit.com I beams for lowering the front end, but are there any other ideas or options? And I haven't found anything for lowering the rear. I don't know if I should remove a leaf spring or ??? I really don't need the full load capacity of a 350 so I'm not worried about that. I really just need to be able to fit it in my garage.
Any info would be appreciated,
Thanks,
Bob
Old 10-18-2016, 07:58 PM
Im50fast's Avatar
Im50fast
Im50fast is offline
Nice guy!
Im50fast has a great reputation on FTE.Im50fast has a great reputation on FTE.Im50fast has a great reputation on FTE.Im50fast has a great reputation on FTE.Im50fast has a great reputation on FTE.
I have thought about this PLENTY. I've researched it some.
Its nearly impossible.
The rear axle is very very very close to the frame/body. The front is very expensive due to the cost of the I beams. Also I believe the aftermarket lowering I beams are questionable quality.
Ive considered seeking front spindles but no one has anything for E series. And I never did find out if any of the F series stuff will fit.
Let et me know if you find answers to these concerns and I'll be on board with you.
Old 10-18-2016, 08:01 PM
Im50fast's Avatar
Im50fast
Im50fast is offline
Nice guy!
Oh and if you cut or change the front springs it will change your camber and likely chew up your tires in a hurry.
cooktimj
16
02-12-2018 01:31 PM
Raider48
1999 to 2016 Super Duty
11-20-2017 01:19 PM
Monstermax4
08-05-2017 07:53 PM
Pokee
02-07-2017 06:45 PM
dieseldrive
11-20-2016 11:56 PM
Quick Reply: Lowering an E350
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
