100% custom Projector Headlights
Old May 22, 2013 | 09:02 PM
frdf250's Avatar
frdf250
I just found this online. I'm not sure if i am the first person to post this up...but this guy is one of the most talented people i know. Check these out.
2012 F250 HID Retro [Completed]
Old May 23, 2013 | 12:16 AM
shadowSVT's Avatar
shadowSVT
those are insane - I want a set
Old May 23, 2013 | 01:17 AM
RM2738's Avatar
RM2738
Cool. Not sure if its the lights I like or the truck they're on more.
Old May 23, 2013 | 05:34 AM
2ndStroke's Avatar
2ndStroke
Wow, painting my headlights stressed me out, this guy is crazy.
Old May 27, 2013 | 12:03 AM
Tim Young's Avatar
Tim Young
Active Streak: 30 Days
That was quite a project. Both the truck and the lights looks good.
Old May 27, 2013 | 05:31 AM
Adventure Rider's Avatar
Adventure Rider
I got a projector light project on the dock, but it pales to what he did. Very nice
Old May 27, 2013 | 07:34 PM
bryyce62's Avatar
bryyce62
Looks great. But way too much work.
Old May 27, 2013 | 09:46 PM
Grout-Scout's Avatar
Grout-Scout
Yeah cool but until someone else makes them commercially I won't own any. I could only wonder how much those rascals would cost per pair?
Old May 28, 2013 | 12:57 PM
B&LLandscaping's Avatar
B&LLandscaping
I installed projectors in mine, my install was no where near the work of art that his is, but it is effective. HID projectors are a HUGE improvement over stock and well worth the money IMHO.
The projectors, ballasts and bulbs run about $400 for a top of the line set.
Old May 28, 2013 | 02:09 PM
Brandon Bloomquist's Avatar
Brandon Bloomquist
B&L - did you take the epoxy in the Ford bowls approach? What are your thoughts on that approach? Any regrets or learnings to share?
Old May 28, 2013 | 05:04 PM
B&LLandscaping
I didn't go the epoxy route. I essentially bolted them to the Ford bowl using the OEM mounting points on the projector housings. I think it worked well and left them adjustable if need be. The downside is that you can't get the projectors as far back into the bowl and the install isn't as clean. I sealed them up using hard but flexible/removable silicone to keep out any moisture and prevent anything from coming loose.
The toughest part is getting the housings apart. Lots of heat, small steps, and patience. The rest is painstaking, but actually quite simple. Measure twice cut once as they say. Just like anything, once you've done it once the next time is a lot easier, if I was to do it again it would take 1/4 of the time and be a cleaner install. There is a learning curve and some trial and error involved. Pay close attention to the left/right alignment and aim, that can't be adjusted with the OEM adjustments, and is critical for best results.
I'm very happy with the results, the FXR projector kit I bought from The Retrofit Source provides great light output and has a nice clean low beam cutoff. The wiring harness was simple plug and play, which is nice, and allows a return to stock in about 15 mins.
Old May 28, 2013 | 07:38 PM
tolliewolly's Avatar
tolliewolly
Those look awesome!
Old May 28, 2013 | 09:36 PM
jimmyv13's Avatar
jimmyv13
Just read the whole thread...unreal!
DarrinGT
41
Apr 9, 2019 09:36 AM
diehardstroker
Jan 30, 2013 05:49 PM
c00nhunterjoe
29
Oct 30, 2007 09:13 PM
aklim
Jun 17, 2007 07:44 PM
