Fittings
30ft of 3/8 ought to do it eh?
New Speedway 3 8" OD Aluminum Fuel Line Tubing 30 Foot Roll | eBay
Also got the check valve for between tank feed and return loop T fitting.
I already have 2 12v selonoid valves laying around that i might use... but im doing my best to keep this as simple as possible.
The filter head that i put on when i went through the hutch mod was purchased with this conversion in mind. It has a built in heater, so i can start heating immediately with 12v... i still need to play with the circuit to see if i can fiddle with temp...
So... electric heat between tank and pump...
Planning TiH from pump to motor.
Return from motor will remain oem to the tank selector... from there... takes its normal path through the alt tank return line... but it does not go to the alt tank...
It T's in between the tank and pump just before the filter... so yes it goes through it again.
The idea is heat retention and switching simplicity...
Yes... there will be pictures. Lots of pictures...
Im leaving the regulator on the fuel bowl... but removing the lines and capping the ports.
The lines are going into a t fitting with a cv for vo.
Vo pump gets turned on... runs at higher pressure than d2... overpowers cv's and pushes its way thru the frx lines to the heads... the cv at the t will keep d2 from backflowing into the vo system.
If it works... it will be the simplest switching design i have seen so far.
Once the design is proven... i will work on the bowl delete and full regulated return.
Eventually i would like to be pushing around 450 on vo.
The last post about the regulator is for that future stage...
Im guessing the cheapo regulator wont pass near enough volume but i love the color so hoping it might work...
Irritating that stainless 12v valves are so dang expensive!
These are the cheapest 12v valves they are aluminum. 1-2 are on all the time when 12v applied 1-3 on. Plug #2
Here is mine I am redoing my system as we speak.
<a href="http://s1305.photobucket.com/user/perryrish/media/image_zpse0e79e72.jpg.html" target="_blank"><img src="http://i1305.photobucket.com/albums/s556/perryrish/image_zpse0e79e72.jpg" border="0" alt=" photo image_zpse0e79e72.jpg"/></a>
<a href="http://s1305.photobucket.com/user/perryrish/media/image_zps001f288c.jpg.html" target="_blank"><img src="http://i1305.photobucket.com/albums/s556/perryrish/image_zps001f288c.jpg" border="0" alt=" photo image_zps001f288c.jpg"/></a>
I've found hydraforce valves pretty cheap from some hydraulic supplier in Salt Lake City, but if forget the name. Something like Hydraulic Services or Hydraulic Systems Inc.
Another alternative is to use WVO Designs selector valves. I've used hydroforce and WVO designs valves on four different WVO cars and all have lasted several tens of thousands of miles.
Hydraulic Controls Distributor-Stockton, California - Hydraulic Controls
I know it says California but hydraforce website said Salt Lake City.
The overall concept of the design is changing.
Im going ahead with the bowl delete/ fuel switching manifold.
Im about to lose 2 more injectors... so its just time for them to be replaced...
And i have noticed some hpop hiccups...
So those have to be addressed first...
But 2-3 paychecks from now i should be able to order some material.
