Master cylinder brake line fitting
Old May 22, 2013 | 06:47 AM
clinkfield's Avatar
clinkfield
I installed all new brake parts on my 66. Master cylinder, lines, wheel cylinders, shoes, etc. One problem - the fitting connecting the brake line to master cylinder doesn't seem to go into the threaded hole far enough to pressure the flared end against the master cylinder body.
In the first picture, I am showing how far into the hole the brake line goes before bottoming out. It's about an inch.
The second picture shows the new brake line with the boogered up fitting that isn't long enough. The threads are about 3/4 inch. (I kept trying to tighten it to get the leaking to stop - eventually just stripped it.) My local auto parts store doesn't have a fitting any longer than that.
On all of the other places the brake lines connect, the depth of the holes is less than half an inch. The fittings screw in and tighten the flare against the bottom and there are still threads showing.
I don't have the original fitting - cut it out and threw it away ...
Any thoughts? Advice?
Old May 22, 2013 | 07:07 AM
schoo's Avatar
schoo
Get another fitting just finished mine a week ago used the old fitting but any good parts shop should have it
Roy
Old May 22, 2013 | 07:16 AM
clinkfield's Avatar
clinkfield
Schoo - Was your old fitting an inch long? I tried two auto parts stores - neither had one ...
Old May 22, 2013 | 07:50 AM
schoo's Avatar
schoo
I don't remember how long it was but I think that they are pipe threads so they taper and mine was old style double flare you should be able to get parts at napa take the old unit in with you
Old May 22, 2013 | 08:26 PM
Jetcopterpilot's Avatar
Jetcopterpilot
looks as though you are trying to put a flair fitting into a NPT fitting... you need to get an adapter, from NPT to Flair fitting. any NAPA
will have the part you need
Old May 31, 2013 | 12:56 PM
clinkfield's Avatar
clinkfield
Jet, thanks for the reply. When I went back to my local parts store - the one that said they didn't have anything that would fit - I told them I needed an "NTP to flare fitting". They brought one right out! I guess it was all in the wording.
The brakes are working great now.
Old May 31, 2013 | 04:35 PM
Jetcopterpilot
Usually the case!
Texas 64 Ford
Mar 14, 2024 05:18 PM
Lee Patrick
Mar 14, 2024 12:02 PM
Cougar54
Sep 29, 2014 05:37 PM
rocdril
Dec 20, 2012 07:11 PM
