1978 - 1996 Big Bronco
it's stuck
Old May 19, 2013 | 05:29 PM
dlocraft's Avatar
dlocraft
it's stuck
I have a 79 bronco w/ 351m And distributor shaft housing broke when trying to remove any advice on how to remove and what type to replace with.
Old May 20, 2013 | 04:04 PM
g_k50's Avatar
g_k50
Where did it break off at? The housing or the shaft?
Old May 20, 2013 | 04:46 PM
GruesomeJeans's Avatar
GruesomeJeans
I've heard rumors of the dizzy housing essentially "welding" itself to the block. I don't know how to remedy this or if it even happens but my brother had a 79 f250 with a 351 and he claimed his was like that preventing him from timing it.
Old May 20, 2013 | 04:57 PM
dlocraft's Avatar
dlocraft
its stuck
broke the shaft
Old May 20, 2013 | 04:58 PM
dlocraft's Avatar
dlocraft
at the shaft about 1" above block
Old May 21, 2013 | 03:57 AM
GruesomeJeans
Can you grab that 1" with some channel locks? Or is the housing in the way? Maybe we could bother you for a picture or 2 so we can see what you're dealing with.
Old May 21, 2013 | 08:29 AM
dlocraft's Avatar
dlocraft
its stuck
yea i'll take pictures tonight and post them. thanks
Old May 21, 2013 | 07:29 PM
MadMatt65's Avatar
MadMatt65
I have seen it happen before on other engines. Keep spraying it with "Blaster" or the new WD40. Do that for a number of days. There is a socket with "jaws" in it made for jobs like this. You tap it on the stub sticking out. Tap LIGHTLY! There also is a "mechanical" socket that will go over the broken piece that tightens the more you pull on it.
First I would keep trying the spray before you go and buy tools you probably won't use again! Channel locks or maybe a good pair of vise grips. Worse case......I saw a guy that had to chisel out a broken dist shaft out of a Pontiac 400 engine!! Wasn't pretty, but he got it!!
Old May 21, 2013 | 11:32 PM
Torky2's Avatar
Torky2
I don't get it... what exactly is stuck? You said the distributor SHAFT.
I could see the housing getting stuck, but the shaft is stuck WITHOUT the housing?
The distributor shaft has the helical gear on it that engages the like on the camshaft, and the bottom end of the distributor shaft engages the oil pump hex drive shaft... what is there to get stuck? I'm confused.
Old May 22, 2013 | 11:05 AM
GruesomeJeans
Pssst, tha'ts kind of why I asked for pictures I couldn't understand either. The only thing I could think of is what I did when I was trying to kind of "rebuild" my dizzy vs spending money on a whole new one.
My awesome hulk like strength broke it All in all, I still had to get a new dizzy and it didn't fix the issue I had... The issue I had was some shoddy wire cuts that the PO had wrapped in tape. They had become disconnected coming from the coil. After replacing the dizzy and a few other things, a neighbor who is a partial car guru came over and asked if I had checked under the tape... I said no of course and he said" Well that's probably your issue.." He cut out the problem areas, butt connected it back together and put the wires on correctly and it fired right up.
Anyways, those was the only thing I could think of unless maybe the helical gear on the bottom has fused to the oil pump or something? Not very likely but until we get more info I can only assume
Old May 22, 2013 | 11:07 AM
dlocraft's Avatar
dlocraft
its stuck
the distributor housing is stuck in block.
Old May 22, 2013 | 11:15 AM
JWC 3's Avatar
JWC 3
Seen that a lot . PB , WD , your favorite spray oil . Soak for a few days , apply a bit of heat with a propane torch and let cool completly . Repeat the heat , cool , soak . It should come out then . . When I pulled mine the first time it was a bear . I then lightly sanded it and cleaned it well . I try to turn it at least once a year now .
Old May 22, 2013 | 11:18 AM
GruesomeJeans
Ah, so it isn't the shaft. Well, I suggest getting some large vise grips and clamping them onto the base, then taking a mallet and giving it a few love taps. With some additional lubing from the good ol WD-40 or maybe some heat from a torch. Then whack the crap out of it. You'll get it out one way or another. If you don't have a large pair of vice grips then you could drill a hole through the top side of the housing and slide a screw driver in there and crank on it. I'm 98% sure the housing isn't going to be usable afterwards so do what you can.
Traderjoe28
Feb 20, 2025 07:22 AM
reamer
Oct 1, 2016 06:31 PM
shark13
Dec 13, 2010 10:21 PM
John7894
Jun 15, 2008 12:19 PM
Darrin
Jul 12, 2003 12:29 PM
