Keeping the Heat
Old May 19, 2013 | 11:54 AM
mueckster's Avatar
mueckster
Keeping the Heat
I recently replaced my GTP38R due to oil leaks from the shaft seals. Before installing the new turbo, I swapped the compressor wheel with one of Riffraff Diesel's new billet 11 vane wheels. I am extremely pleased with the outcome of this install. Being me, I wanted that little bit more. I had tossed around the idea of adding a turbo blanket around my 1.15 A/R turbine housing, in addition to the ceramic coating, to "keep the heat" where it belongs to add efficiency to the exhaust flow and away from the cold side. I decided to give it a try, since I had already wrapped the uppipes last spring. I am hoping to see a little better spool up and reduction of underhood temps. I monitor my intake temps at the spider, so I'm curious to see how much difference I'll see at that point.
Old May 19, 2013 | 12:03 PM
woodnthings's Avatar
woodnthings
Roland, That looks like it fits perfect! Good job, I am sure it will reduce the heat loss.
Old May 19, 2013 | 12:09 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
That's BA. Nice tight fit. What kind of wrap is it?
Old May 19, 2013 | 12:57 PM
mueckster's Avatar
mueckster
It is a hand sewn blanket from Xtreme Parts World. They come in different sizes. I emailed them and told them my application. It is sized to fit a large T4 - small T5 turbo.
Old May 19, 2013 | 05:00 PM
bfife's Avatar
bfife
still plays with trucks
nice! I don't know if it would fit with my exhaust brake. it bolts up where the EBPV used to be. I also want to wrap the down pipe about 3 ft. keep all the heat in, help with the flow, don't cha know. I don't know where the point of diminishing returns is. Should we keep the exhaust temps up til it reaches the muffler? or is 30 in enough?
Barney
Old May 19, 2013 | 05:19 PM
mueckster's Avatar
mueckster
One drawback is only being able to use these blankets on nonwastegated housings. I might consider wrapping the downpipe, as well.
Old May 19, 2013 | 05:41 PM
Pitcrw6's Avatar
Pitcrw6
Interesting to see what kind of results u get.
Old May 19, 2013 | 06:19 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I like it. I've thought about powdercoating my IC pipes. But I cant decide on a color.
Old May 19, 2013 | 09:16 PM
BadDogKuzz's Avatar
BadDogKuzz
Roland that is a really nice turbo wrap, fits nicely !! You know I am a big fan of wrapping exhaust stuff. I have my up pipes and down pipe wrapped. Now I went about 30 inchs down but in hindsight I wish I would have wrapped it past the tranny lines. Since where I stopped was right before the trans lines. I don't like the idea of heat transfer to the tranny lines.
So I am looking forward to hearing your results. Keep up the good work and I am sure you'll get over the 500hp mark at RRE this year!!
Old May 19, 2013 | 09:54 PM
mueckster's Avatar
mueckster
Thanks, Ed. It had hooks on the outside to retain it with tension springs, but I didn't use them. You can't hardly get back there and it's holding nicely without them. I'm going to see how it goes with the blanket before going any farther. I'd like to see how much each stage of heat retention plays its part. Every little bit helps. I spent time with the better half today and will test drive it and report tomorrow.
Old May 20, 2013 | 06:40 AM
DISLFVR's Avatar
DISLFVR
Locomotive breath
Interested in your results as well, do you expect a mpg's improvment?
Old May 20, 2013 | 07:08 AM
joeyd61's Avatar
joeyd61
Roland,
wish I could help with before and after but when we built the motor, I had the turbo,up-pipes,down pipe, ceramic coated and wraped the up-pipes/down pipe and installed the turbo blanket..
Old May 20, 2013 | 04:07 PM
F-250 Super Duty's Avatar
F-250 Super Duty
Looks great! Hope it provides some results worth the cost. Was it expensive?
Old May 20, 2013 | 10:16 PM
mueckster's Avatar
mueckster
It wasn't really planned as a fuel economy improver, but it looks like I'm seeing a reduction in intake air temperature which will relate to a better charge of oxygen to mix with the fuel. I'm hopeful it will be beneficial. Just the insulating factor is helping with keeping the compressor side a bit cooler and lowering intake temps ~ 4-5 degrees.
SOTP feel tells me the acceleration/spooling has improved somewhat. Nothing drastic, but noticable. The blanket was $69.95 + shipping.
Old May 21, 2013 | 08:03 AM
mueckster's Avatar
mueckster
Barney
I found this and ordered it last night.
HeatShield 176001 Heatshield Armor 1/2" Thick x 1' Wide x 3' Hot Pipe Kit with 4 Stainless Steel Ties : Amazon.com : Automotive HeatShield 176001 Heatshield Armor 1/2" Thick x 1' Wide x 3' Hot Pipe Kit with 4 Stainless Steel Ties : Amazon.com : Automotive
I had some cashback credit on my Discover card and got it for < $12, out of pocket. I used the same stuff to wrap my uppipes last year.
(For some reason, the link posted twice...)
