E40D slipping when taking off
Old May 18, 2013 | 10:42 PM
F250IH's Avatar
F250IH
92 f250 e40d with approximately 80xxx miles slipped when taking off yesterday going to work. Checked codes and getting a 14 & 29. Just replaced the vss but will replace again. The 14 is the tach sensor I believe so tested the ohms and its reading 2,400 so it should be good. Checked fuses in the cab and they all looked good. Now checking the fuses under hood but there are 4 or 5 that "control the transmission". Which one should I check? Also, can the tach sensor still be bad even though it reads in the right ohm range (read that the ohms are supposed to be between 2000 and 3000 ohms)? Anything else i need to check? Ps I have a trans commander but just bypassed it to remove it from the possible problem and clearing codes. Check codes again tomorrow after I replace the vss. Any help would be greatly appreciated.
Old May 19, 2013 | 02:01 PM
F250IH's Avatar
F250IH
After clearing codes I'm getting code 23. Throttle sensor out of range. Will replace tomorrow and run codes one more time.
Old May 19, 2013 | 05:58 PM
Red454sedgwick's Avatar
Red454sedgwick
clean all of the eletrical conetions, and how burnt is your fulid
Old May 20, 2013 | 09:02 PM
F250IH's Avatar
F250IH
Doesn't look/smell burnt. As far as the code goes apparently it is the FIPL out of adjustment. Will post update when/if I can get it adjusted.
Old May 20, 2013 | 09:15 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
do you notice either the tach (code 14) or speedo (code 29) needles reading incorrectly,skipping,or not working at all?
for the fipl/tps (code 23) did you hold WOT while scanning the codes? if not,23 is sent.
Old May 21, 2013 | 09:33 PM
F250IH's Avatar
F250IH
I held wot until the test started. Do you hold wot the entire tests? Anyways just finished putting new FIPL on and adjusted,after warming the truck up, and have it set at 1.1 idle and 4.1 wot. Why would it be tight inside the acceptable limit? Seems strange... I wanted to set it higher but threw me out side of the 1.1. I got the code 14 when I first tested it but didn't after I cleared codes. I tested the tach sensor and it tested at 2400 ohms.
Old May 23, 2013 | 05:32 PM
F250IH's Avatar
F250IH
Do you have to wot the entire test?
Old May 23, 2013 | 05:51 PM
FORDF250HDXLT
yes.
more info on tps adjustment:
https://www.ford-trucks.com/forums/1...ions-only.html
code 14 (tach sensor/wiring issue) may not return until you drive the truck for a bit again after clearing the code.don't be surprised if it returns shortly.
current thread of interest;
https://www.ford-trucks.com/forums/1...gine-that.html
Prototypemech
Dec 2, 2013 08:54 PM
saengjwi
Sep 6, 2006 08:10 AM
k_rok
Mar 20, 2006 10:16 PM
Tim Halliday
May 18, 2004 05:46 PM
RJMACK
Jun 2, 2002 09:06 PM
