Compatible Injectors
Old May 18, 2013 | 08:40 PM
cgiles85's Avatar
cgiles85
I have an 89' F150 with a 351 Windsor from a 1990 Crown Vic.
Im going to change the injectors which currently have the stock number E5TE-B1B. My question is, what are the compatible injectors that will fit in this engine? I do not want to upgrade, i would just like to keep the stock injection pressure.
Old May 18, 2013 | 08:53 PM
Evan_P's Avatar
Evan_P
Read the injector rebuild guide in my signature. Following that you can rebuild your current ones for ~$25.
Old May 18, 2013 | 09:29 PM
cgiles85's Avatar
cgiles85
Thanks for that, I will definently consider it. I would however like to replace them with new. Any charts or lists for compatibility?
Old May 18, 2013 | 09:45 PM
Evan_P's Avatar
Evan_P
As long as your current injectors look like what I showed in that write up, these will work:
http://www.summitracing.com/parts/ac...rd/model/f-150
That write up also has a list of the Ford vehicles that should use those type of injector, Just make sure that when your looking at new ones you look at ones that are 19lb/hr.
Old May 18, 2013 | 11:44 PM
cgiles85's Avatar
cgiles85
Thanks, I was worried that the E5TE-B1B number had to match.
Old May 19, 2013 | 10:19 AM
Conanski's Avatar
Conanski
No that number on the injectors is just a date code, these things were manufactured right up past Y2k so as long as you put back 19lb/hr(yellow top) injectors for a Ford you're good.
Old May 19, 2013 | 11:53 PM
cgiles85's Avatar
cgiles85
Awesome, thanks thats what I wanted to know.
Old May 20, 2013 | 11:34 AM
austinlittle34's Avatar
austinlittle34
Will those dri injectors work on a 4.9 i6
Old May 20, 2013 | 11:51 AM
Evan_P's Avatar
Evan_P
Ony if you can find some that have the correct flow rate. I believe the 4.9 uses smaller (flow rate) injectors. Throwing larger ones in would cause it to run rich.
Old May 20, 2013 | 04:52 PM
austinlittle34
Do you know what the flow rate is on say your dri injectors and are you talking like cfm or gph or are you talking about how many pounds of pressure
The FNG
May 25, 2014 06:07 PM
Intimnasc
Mar 22, 2013 11:32 AM
catman52987
Jan 29, 2012 10:37 PM
MikeDehner
1978 - 1996 Big Bronco
Jun 28, 2010 07:51 PM
suzuki_vinson
Nov 1, 2008 10:13 AM
