how do I bake spec d lights?
Old May 16, 2013 | 09:11 PM
FlooringGuy's Avatar
FlooringGuy
I have a pair of dual halo spec d headlights and I really like them, however, the housing is all black but the projector section is chrome. I have a black and white truck theme and no chrome and was wondering if it was easy to open them up to paint them and then reseal them and how I would go about doing that. I am not familiar with this process but heard of it being done. The front of the headlights is plastic not glass. Any directions or help would be appreciated.
Old May 17, 2013 | 05:07 AM
2ndStroke's Avatar
2ndStroke
I never did my f150, but I did my f250. Put the housing in the oven at around 200 for a 5 to 7 minutes, take them out and start pulling them apart, I used a butter knife to pry, it will take a few times in and out of the oven before you get it apart. Then I used auto silicon to seal them back together, used zip ties to hold the housing together tight while the silicon dried.
Old May 17, 2013 | 10:12 AM
FlooringGuy
Thanks man, appreciate the help! Would you put a wet cloth over the lens to protect it or does it not get that hot? Do I have to worry about moisture or vapor by opening them? Thanks again, kind of a noob to this type of mod.
Old May 17, 2013 | 03:12 PM
2ndStroke's Avatar
2ndStroke
I hear ya, shoving your lights in an oven is kinda stressful, but it definitely worth it for the end result. Overall, its a pretty easy project, just takes alot of time, took me the better part of the weekend to open, paint and reseal. I never put a cloth, I did kind of double up tinfoil for a pad to protect the bottom, but most guys say you don't need to. Do you mean moisture after you reseal them? I did mine close to a year ago, made it through one nasty winter and they are still clear. I will try and find the video I used to make my plan of acton when I did mine.
Old May 17, 2013 | 03:28 PM
2ndStroke's Avatar
2ndStroke
Old May 20, 2013 | 05:53 PM
FlooringGuy
Thanks for the help, this may be a dumb question but do i need to strip out the sealant that is currently there before resealing? Just want to make sure I do this right.
Old May 21, 2013 | 01:22 AM
FlooringGuy
Never mind, figured it out. Most of the old sealant stayed in place and I was able to reactivate it by sticking the housing in the oven again and pressed the pcs together. Worked like a charm, I did still add a new bead of silicone just for good measure. Thanks for the help, they look a lot cleaner now!
Before:
After:
Old May 21, 2013 | 06:56 AM
2ndStroke's Avatar
2ndStroke
Right on, that looks awesome. Great job.
Old May 21, 2013 | 11:44 PM
FlooringGuy
Thanks for the reputation, I'm new to the forum, what exactly is it?
jgarrison31
Feb 24, 2019 01:53 PM
johnboy74
Jun 20, 2017 04:54 PM
mikerans
19
Sep 19, 2013 03:50 PM
agator
2004 - 2008 F150
17
Dec 30, 2012 12:28 AM
phoneman91
Appearance & Dress-Up
Apr 3, 2010 07:25 PM
