Overheating! Opinions please
Old May 16, 2013 | 07:12 PM
RideDiesel88's Avatar
RideDiesel88
Well i replaced my radiator because i broke the little nipple on the degas return line and i was losing coolant like crazy. Well it was still losing coolant after a new radiator so i replaced the water pump and im not leaking coolant at all anymore.
Before all this, after towing 4k all day my EOT would get up to 202 or so and ECT 195 197. Now after the work, my EOT gets up to like 217 and ECT at 210. Also my trans temp would never go over 165 and now its gettin up to 180. Anybody know whats goin on? any opinions or anything would be greatly appreciated.
Old May 16, 2013 | 07:45 PM
dannyboy950's Avatar
dannyboy950
Did you purge the air out and top backup the system. Do you have the right mix?
OEM or aftermarket radiator?
Old May 17, 2013 | 07:56 AM
Curt's05's Avatar
Curt's05
Wiser by FTE
After your engine is warmed up, you should carefully open the degas cap. You may have to do this a couple of times.
Old May 17, 2013 | 04:09 PM
RideDiesel88
Is that what your supposed to do when you swap radiators? I just hate having to open that degas cap and weaken that spring. And yes im using 5050 mix of ford gold and distilled with a replacment oem radiator. But since my trans temp has been going up to, i guess it is related to my radiator. I didnt know trapped air could raise the temp. I only got it up to 190 today and i purged the air but monday when i dog it ill check it again. thanks for the input.
Old May 17, 2013 | 05:12 PM
cheezit's Avatar
cheezit
really with warmer weather here already those numbers dont really look to bad.
Old May 17, 2013 | 05:20 PM
RideDiesel88
O i know. i was thinking that too. Its about 85 here in virginia right now. But its the fact that the numbers are different from usual. and its after i did work. Have you heard of air trapped in the system getting the EOT up? along with the tranny? Is it spec to start up the truck before finally closing the degas cap after the install?
Old May 17, 2013 | 05:51 PM
Misky6.0's Avatar
Misky6.0
Make sure your radiator fan is working, perhaps you didn't get the connecter plugged all the way in?
Old May 17, 2013 | 07:18 PM
cheezit's Avatar
cheezit
that would be the one thing make sure the fan is pluged in.
the radiator has an oto transcooler + you have a trans cooler in front of the radiator. all the temps will climb a little as it get hotter outside.
air pockects are not common in the 6.0 but can happen. i have always just let the truck run for 30 min or so to hit operating temp with the cap off and let it purge itself
Old May 17, 2013 | 09:38 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
If the fan wasn't plugged in, wouldn't he get a code/cel?
Old May 18, 2013 | 06:32 AM
cheezit's Avatar
cheezit
yes.........
Old May 18, 2013 | 12:26 PM
RideDiesel88
ya the fans plugged in... thanks for the input. looks like I got some of yall thinkin. sounds like letting any extra air outta the cooling system could get the temps back down. Ill just keep an eye on it and post back
Old May 18, 2013 | 12:52 PM
cole.nelson's Avatar
cole.nelson
If you have an air bubble the pump will cavitate which will keep the coolant form circulating throughout the system check the temp difference between the upper and lower radiator hoses.
Old May 18, 2013 | 01:36 PM
RideDiesel88
So how do I get rid of any air bubbles? and how could I have prevented it?
Old May 18, 2013 | 04:33 PM
cheezit's Avatar
cheezit
or a rad kit
Hennington400
16
Sep 20, 2016 07:10 PM
___
Aerostar
Nov 19, 2007 09:11 PM
MRKnight
General Automotive Discussion
Jun 16, 2006 11:22 PM
armybronco2
Bronco II
Nov 20, 2005 10:13 PM
90 AWD
Aerostar
Nov 5, 2005 03:18 AM
