Front needle bearings
Chet
In comparison, I took a video of me doing the same thing on my truck and there was ZERO flex or movement.
I may get spunky enough later today to take an after video on the dually for direct comparison. (I couldn't get a before clip of the passenger side,which was much worse, because apparently when an iPhone sits in the sun for three hours it goes into shutdown mode until it cools off...)
I'm not going to reinvent the wheel, guzzle did a fantastic write up, no point in doing another, but I will post the results
Surprisingly, everything came off relatively easy. The toughest part was hammering the old seals off if the axle shafts. The driver side needle bearing wasn't as bad as I had expected, but after driving it out we could feel a LOT of grit. How did sand/dirt get in there? Well there was no yellow oring, so every time the hubs tried to lock automatically the vacuum pump would suck unfiltered air in.
. We took our time with a wire wheel on the drill and cleaned everything up really well, including the inside of the knuckle, polished the groove for the yellow oring, and got rid of any grime before reinstalling. We also checked the slide pins before reinstalling and they were fine. We hit a snag when we got ready to drive the new seals on. I couldn't find the old seal driver that I had made (think it got left in My other truck after the wreck), and none of the parts stores had one. So into Home Depot for an 8" piece of 1-1/4" galvanized pipe and a 1-1/4" pipe flange. The flange had to be ground down a bit to fit inside the seal like its supposed to, so about 10 minutes on the grinder and we were ready to go.
(There was a thread here where somebody made one this way, but they had a lathe. They actually squared the handle to the base so that the seal would drive perfectly even. We simply rotated 15-20* after every tap to compensate. Works like a charm)
To clarify real quick, it's not necessary to replace these seals when doing needle bearings. We replaced them because the auto hubs were not functioning properly, and that was the last step to rebuild the vacuum system (knuckle seal, yellow oring, and black oring).
So driver side done, nothing notable for pics really. Passenger side though, there were some issues there. First off, we forgot to take the snap ring off the axle shaft. Turns out the hub doesn't like coming off with the snap ring in place. We realized and it slid right off. What a mess we saw.
Don't know if any explanation is necessary. Tons of grit, grime, and grust (most likely due to a bad knuckle seal (the yellow oring was there on this side) caused the bearings to freeze up, resulting in them grinding down. The vibration is due to a hoola hoop motion that is created by the resulting gap. Locking the hubs like pop said above will force the shaft to spin with the hub, keeping the bearings from grinding down any further and/or damaging the axle shaft.
We did inspect the axle shaft, and found a slight amount of wear. We polished it a bit with a hand file and wire wheel and figured that dog would hunt.
Then we ran into stuck slide pins. Another hour set back driving the old pins out and cleaning the bracket holes real good. New pins installed and everything back together. Oh we also greased the main bearings through the abs holes as well. No more vibration and the auto hubs work once again (although I suspect te vacuum pump is getting very tired).
Thanks again Rob for all the help. Really enjoyed it.
But anyway, glad we got it all back together and even had some time to do some data logging.
