removal of cats
removal of cats
I have a 1998 f250 gas job,, with a flowmaster single in dual out muffler nd want more roar!!!! Ive been considering having 4 cats removed?? But leaving o2 sensors in,,,,,, will this cause problems?? I have been told go for it, dont do it, my one buddy has a 92 f150 nd said first thing he did was remove em , nice high flow with glass pack nd said I should do it
I dont know who to believe please help thanks
The sensors after the cat will throw a check engine light because the exhaust that was supposed to be getting cleaned up by the Cats is now loaded with nasty gases and the computer cannot adjust the engine enough to clean it up.
You may not be subject to emissions inspections, but aren't you required to have the safety inspection? If so, read on:
PA DEP I/M - Information for Drivers in "Other Counties"
To get rid of the CEL after cat removal, you need some kind of chip or simulator to send the correct signal to the ECU to keep the engine running as though all things were normal.
Something like this:
SINGLE MIL Oxygen Sensor Simulator, MIL-Eliminators.com
Since you just want to make noise, consider:
Truck and Train Horns : Air Horn Kits : SuperiorHorns.com
This will get you noticed:
Whatever floats your boat.
Yes even if you leave the O2 sensors in without the cats you will still get a check engine light. Like stated above you might be able to find a programer to fool the Pcm into thinking the Cats are there but to me it seems like a lot of hassle to make your truck smell like crap and pollute the air. And keep in mind that it is illegal in the US to tamper with a Cat so most shops wont touch it. If you are removing them yourself thats different still illegal but unless you have inspections you probably can get away with it untill you sell the truck that is..
