Help!!!!
Old Jun 7, 2003 | 06:59 PM
Zinfinity's Avatar
Zinfinity
Exclamation Help!!!!
Hey guys, i got a problem, 1992 F-150 5.0L 4X4 E4OD, Earlier this afternoon, my truck started sputtering when accelerating from stop. I take my foot off the brake and press on the gas only to have the engine putter and wheez, it feels like the truck is about to stall out, but it doesn't. Then after a few seconds power is back to normal and i continue to accelerate. Does anyone have any clue as to what my problem is? I would like to recify this problem asap.
Thanks in advance!!
Jeff
Old Jun 7, 2003 | 07:46 PM
steve83's Avatar
steve83
Help!!!!
The subject line of your post should indicate something about the problem.
Your first step on an engine problem is ALWAYS to pull the codes and diagnose whatever system is indicated, using the test procedures in the Haynes manual. You'll probably need a multimeter ($10-50) and a vacuum gauge to check the pressure at idle.
Old Jun 8, 2003 | 01:22 PM
Zinfinity's Avatar
Zinfinity
Help!!!!
Before i have time to pull the codes, does anyone have any thaughts on what it might be? Has anyone had this problem?
JeffK
Jul 14, 2015 04:14 PM
jeff_E
Electrical Systems/Wiring
Oct 22, 2006 07:53 PM
Jeff$ery
1983 - 2012 Ranger & B-Series
May 31, 2006 06:43 PM
tazmanian_cowboy
Car/truck Buying Advice
Nov 6, 2004 10:22 AM
Jeff Vierling
23
Jun 23, 2004 11:48 PM
