Getting ready to tackle....
Old May 14, 2013 | 09:37 PM
Teamrope's Avatar
Teamrope
Rear breaks. Pedal is a little mushy and the parking break don't hold for s....quat. Also had a little bit of smoke coming from the pass side drum the last time I drove it. It didn't smell like shoes, and I see it is a little bit damp, but not soaked. Looks like I'm gonna have to buy the special hub nut tool.
Anything I should keep an eye out for or any issues I might run into?
Old May 14, 2013 | 09:42 PM
ReBilld's Avatar
ReBilld
Make sure the wheel cylinders aren't leaking. Just had to rebuild one the other day.
Old May 14, 2013 | 11:55 PM
Teamrope's Avatar
Teamrope
The one on the right side is leaking.
I didn't realize the hub did not need to be removed to get the drum off. I'm used to them being all one on 3/4 ton & above from the old days. I pulled one axle shaft out and noticed some kind of adhesive or sealant on the bolts that hold the axle shaft. What should I use & what are the torque specs?
The front shoe break material had completely separated from the shoe on the right side and the inner seal is wet... Feels real thin like break fluid so I'm just going to replace the wheel cylinders & hardware kit
The drum is also scarred so I hope it can be turned.
While I'm at it I have a parking break cable that has been compromised.
Old May 16, 2013 | 08:27 PM
Usaman's Avatar
Usaman
Did mine last week; new drums, shoes and e-brake. Left was leaking when I pulled it and believe it or not, I had a spare seal in the glove box from a couple of years ago when I did the front and it fit!!! take that to the bank!
jawroper
Jun 2, 2015 08:35 PM
zakk
15
Mar 12, 2011 06:05 PM
78workhorse
30
Oct 27, 2008 05:42 PM
struggler
Jan 20, 2008 01:03 AM
Bouts21
Jan 30, 2005 07:14 PM
