Wheel spacers
Old May 14, 2013 | 03:40 PM
Jarryd's Avatar
Jarryd
Wheel spacers
Anybody ever use these instead of different offset? It's basically the same concept when using hub centric wheel spacers.
Also, if I used these, could it cause my wheels to come farther forward when turning and cause me to run the bumper rather than the radius arms?
Old May 14, 2013 | 04:00 PM
GNR22's Avatar
GNR22
People use them, they are definitely not as safe as just using rims with less backspacing. I know a few people use them on the rear wheels so the truck tracks the same on front and back. But I would just get appropriate rims for your application.
Yes your wheels won't turn in the same position that they do now. If they hit the bumper, you can just trim it until they don't hit.
Old May 14, 2013 | 04:25 PM
Jarryd's Avatar
Jarryd
I was going to space out the bumper but don't know how far I'll need to do it if I runspacers so it will clear.
Old May 14, 2013 | 04:45 PM
GNR22's Avatar
GNR22
You could do that I suppose. If it still doesn't clear after spacing the bumper out, you'll probably have other problems with clearance.
Old May 14, 2013 | 06:00 PM
Jarryd's Avatar
Jarryd
Now I'm wondering how big of a spacer it will take to clear the radius arms.
Old May 14, 2013 | 08:04 PM
BigBlockF350's Avatar
BigBlockF350
Spacers are okay. Would rather get wheels with different backspacing. If you're going to use them, use aluminum ones. Also use PLENTY of Loctite on the studs when you secure the spacer. Torque them well. There have been accidents where the spacer and wheel will come off together because the people don't use Loctite on the studs and/or torque properly when putting the spacer on.
Old May 14, 2013 | 08:22 PM
Jarryd's Avatar
Jarryd
Yea I know all that. I'm not new to the idea of spacers, I'm just wondering what kind of issues I'll run into with my bumper and how big of a spacer to run for my radius arms not to rub.
Old May 14, 2013 | 08:53 PM
Puddy's Avatar
Puddy
Are you driving on road or off.
Old May 14, 2013 | 08:55 PM
BigBlockF350
What size spacers are you looking to use? With small spacers, you may not need to adjust the bumper.
Also, I can't remember if the 9th generation trucks also have this, but some of the earlier trucks have an adjustment bracket that allows you to move the bumper up slightly. My '88 has that.
Old May 14, 2013 | 09:11 PM
Jarryd's Avatar
Jarryd
I don't think they do. I'd love if I could move it up an inch or so. The valance is the only thing I've had issue with.
Just on the road, most off road it will see is driving through some grass or a dirt road but even that is unlikely. I won't be doing any aggressive stuff that would test the suspension.
Flip4ford
Kansas Chapter
1181
Feb 15, 2021 02:57 PM
aj1434
Dec 22, 2016 05:36 PM
96grimreaper
Aug 5, 2012 08:24 PM
patman247
Nebraska Chapter
Jan 30, 2011 07:47 PM
95-F250
Oct 10, 2006 08:37 PM
