Offroad & 4x4
79 f150 4x4 driveshaft HELP please!
Old 05-13-2013, 10:11 PM
bigcountry62's Avatar
bigcountry62
bigcountry62 is offline
I just swapped my 203 for a 205 (400,c6, longbed 79 f150) and the driveshaft needs to be lengthened it comes to 69 3/4 inches, is that to long or okay, it's a dd and offroad rig, I need a reply ASAP
Old 05-13-2013, 10:47 PM
73 ford guy's Avatar
73 ford guy
73 ford guy is offline
What do you mean is it too long? How short is yours now from working?
Old 05-13-2013, 10:55 PM
bigcountry62
About 8-9 in to short and 69 3/4 is where it needs to be
Old 05-13-2013, 10:59 PM
73 ford guy
You either need to find a 79 f150 with a np205 and get the rear shaft( assuming yours is not lifted and both are stock height) or just get a shaft that is longer and get it cut to length and balanced,anywhere from 50-$150 job at a driveshaft shop.
Or get out the driveshaft stretcher
Old 05-13-2013, 11:22 PM
bigcountry62
It's lifted 4in, but is that TO long meaning unsafe for dd purposes??
Old 05-13-2013, 11:24 PM
73 ford guy
Whaddya mean too long?? A 2wd trucks shaft is even longer
Old 05-13-2013, 11:33 PM
bigcountry62
That's what I thought, but the shop that's doin said it should be fine but he called another shop and they said unsafe over 2500rpm and I should do a 2 piece center bearing thing like on Chevys
Old 05-13-2013, 11:37 PM
73 ford guy
Should be fine as long as you balance it and don't go with a heavy wall tube.harder to balance
Maybe others may chime in..
Old 05-13-2013, 11:42 PM
bigcountry62
That's also what I thought and what the shops doin, I just wanted some others opinions, so I think ima just do it and call it good
Old 05-14-2013, 03:25 AM
tjc transport's Avatar
tjc transport
tjc transport is offline
i ain't rite
Received 3,281 Likes on 2,280 Posts
the other shop wants to sell you more stuff. 2 drive shafts and a carrier bearing setup cost a hell of a lot more than one drive shaft.
Old 05-14-2013, 05:39 PM
captain p4's Avatar
captain p4
captain p4 is offline
There is no 2 piece/carrier bearing on a stock 4wd 70s F150.. it will be fine.
Old 05-14-2013, 06:58 PM
alpha/omega's Avatar
alpha/omega
alpha/omega is offline
^^^"listen to this man. He is my personal attorney."
Old 05-14-2013, 07:15 PM
bigcountry62
That's what I thought, so ima just get her done and go from there REALY apriciated guys!
bigcountry62
05-14-2013 09:17 AM
phil75j
02-11-2013 05:53 PM
1978fordf250
05-10-2007 06:01 PM
havi
02-03-2006 06:29 PM
Quick Reply: 79 f150 4x4 driveshaft HELP please!
