cyclinder with 60lbs
Old May 17, 2013 | 11:02 PM
mike L's Avatar
mike L
Originally Posted by UNTAMND
Marvel is a great additive. I've used it in my oil a lot.
It unsticks lifters and quiets tapping and is a good sludge remover by breaking down the gummy crap.
It says to replace a quart of motor oil with mystery oil. It doesn't say that I have to change the oil right after running for 50 to 100 miles. I guess after that many miles the oil will be black?
thanks
Old May 17, 2013 | 11:25 PM
UNTAMND's Avatar
UNTAMND
Just add it. 1 quart over isnt going to cause any issues.
You can run it as long as you want. We used to add marvel oil in the winter to thin down the oil in the old f800s and in the school busses.
It won't hurt it to be in there all the time. Change it after 1k the first time though. It's gonna loosen up some sludge.
Old May 17, 2013 | 11:33 PM
mike L's Avatar
mike L
Suck the Seafoam through the port in the throttle body used for the canister purge solenoid.
So it's the rubber hose coming off the throttle body rubber hose , that has the purge solenoid. Pull the hose off the purge solenoid so I can suck the Seafoam into the throttle body. Then it sucks it into the intake manifold?
Old May 18, 2013 | 12:20 AM
GoinBoarding's Avatar
GoinBoarding
I had an exhaust valve get so full of carbon it would no longer close, and I saw 60psi on that cylinder only. Probably not your issue: my truck had a broken oil expander ring and burned about a qt of oil every fill up (400 miles or so), which eventually gummed up the exhaust valve enough so it wouldn't even close.
Could you have a burned exhaust valve from running lean with that air leak? Makes sense to me. I'm curious to see what this turns out to be.
Old May 18, 2013 | 02:53 AM
mike L's Avatar
mike L
I thought you can blow valve cover gaskets, by adding oil above the max fill line. Or is that only on the smaller 4 cyclinder engines?
JRROTH1
Modular V8 (4.6L, 5.4L)
13
Jan 5, 2016 02:36 PM
ben101337
May 19, 2014 12:24 PM
Hamberger
Jan 11, 2008 12:35 PM
Ranger GT2
Apr 3, 2007 02:57 PM
51truck
Nov 5, 2003 12:26 PM
