Fuel issue
Old May 11, 2013 | 09:54 PM
geo_1069's Avatar
geo_1069
Fuel issue
Working on my brothers 90 F150, rear fuel pump not running, replaced it, still not running, front pump works fine. Switch on dash is changing gauges, just not sure if it is switching the tank valve. Not very familiar with Fords. Can someone help please?
Old May 11, 2013 | 10:01 PM
JWC 3's Avatar
JWC 3
I think I am correct in thinking the switch may be bad . I have replaced some for this issue . The gauge may switch , but power to pump is not supplied . If you pull the switch and see a melted mess , you found the problem .
Old May 11, 2013 | 10:04 PM
geo_1069's Avatar
geo_1069
Thank you, I will take a look tomorrow, have you got time to talk about a 95 now?
Old May 11, 2013 | 10:16 PM
JWC 3's Avatar
JWC 3
What issue do you have with a 95 ?
Old May 11, 2013 | 10:22 PM
geo_1069's Avatar
geo_1069
first off i'm only running off rear tank, front has hole in it. it has an intermitten power problem, i think also fuel, it boggs down, poping back threw the intake, after a few seconds it will pick back up and run right. its had full tune up and fuel filter.
Old May 11, 2013 | 10:35 PM
JWC 3's Avatar
JWC 3
Popping through the intake is usually lean condition or plugged exaust . I would start with a fuel pressure test . Codes may help also .
jskeith47
Jan 24, 2015 01:46 PM
Demeron
70
Oct 26, 2012 08:11 AM
gearhead351
Sep 27, 2009 07:11 PM
76CamperSpecial
May 31, 2008 11:35 PM
ford91f150
Jun 17, 2004 09:23 AM
