Engine Sensor +5V Reference Signal
Old May 11, 2013 | 08:49 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Which sensors share the +5V signal? I have come up with ICP, IAT, EBP, EOT, EOP and ECT. Do these all use the signal? Any others I forgot?
Also, what would cause a bias in the signal? A short or open sensor?
Old May 11, 2013 | 09:42 PM
carltonwebb's Avatar
carltonwebb
I think MAP sensor gets it too.
Old May 11, 2013 | 11:23 PM
Chipworkz's Avatar
Chipworkz
I sure have have been referencing Wood-N-Things a lot lately.
Taken from the 2002 manual.
5 Volt VREF (CPS, MAP, EBPS, ICPS) is what is listed but it also hits pin 10 on the Throttle Position Sensor.
Here is the link to check it all out yourself. https://sites.google.com/site/woodnt...uty-electrical
Follow Pin 90's path.
Old May 12, 2013 | 11:27 AM
woodnthings's Avatar
woodnthings
VREF is used by these 3-wire sensors: Accelerator Position, Manifold Absolute Pressure, Barometer (Internal to PCM), Injection Control Pressure, Exhaust Back Pressure, Cam Position.
Look at the My Colored Wiring Diagram. The Lower R/H corner has most of the sensors and you can trace Pin 90 (VREF) from the PCM to see what gets it.
grayghost79
Apr 18, 2019 06:10 AM
WB4IUY
Escape & Escape Hybrid
Nov 26, 2014 04:35 PM
Workin4ALivin
Jun 28, 2009 03:41 PM
dlburch
Jan 12, 2008 10:47 PM
ernesteugene
34
Oct 6, 2007 06:31 AM
